02-22-2019, 02:33 PM | #1 |
Will this fit?
My '72 Project GMC has a '79 350 and will be pulling it soon to detail it etc.
Saw this on ebay and would like to install but description is for a flat tappet and not a roller cam application. GM SBC V8 CHEVY HD DOUBLE ROLLER TIMING CHAIN SET 5.7L 283 305 327 350 383 400 https://www.ebay.com/itm/19198832536....N36.S2.R2.TR3 |
02-22-2019, 03:42 PM | #2 |
Re: Will this fit?
I can't see the eBay item (I'm at work right now) but your 79 is a gen 1 SBC so it should fit. I recommend going with a quality part like a Cloyes chain.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
02-22-2019, 03:50 PM | #3 |
Moderator
Re: Will this fit?
Google Cloyes C3023X Engine Timing Set
Amazon lists it for $27.78....and its Cloyes... Pic on your ebay list shows single lower keyway gear.... Cloyes sets have a three key lower gear in case you want to advance or retard the cam...depending on usage etc.... Cant figure out where the other set is made...Cloyes is local US made as far as I know.... Hope this helps:
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
02-22-2019, 03:54 PM | #4 |
Re: Will this fit?
Yes it will fit - but completely agree with AussieinNC, Cloyes is probably the best basic double roller timing chain available, and they aren't necessarily more expensive.
02-23-2019, 10:53 AM | #5 |
Re: Will this fit?
TY for replies and Cloyes it will be.
02-23-2019, 02:54 PM | #6 |
Re: Will this fit?
Cloyes Gear C-3023X - Cloyes Heavy-Duty Timing Sets
Compare Timing Chain and Gear Set, Heavy Duty, Double Roller, Iron/Billet Steel Sprockets, Chevy, V6/V8, Set $25.00 on summit and the one you need. |
02-23-2019, 03:52 PM | #7 |
Re: Will this fit?
Found it on ebay for "best offer" and free shipping. TY for info. very much appreciated.
