Old 06-30-2020, 11:56 PM   #1
elkniks
elkniks's Avatar
window track inside door
Is the short piece of track for the widow regulator spot welded onto the inside of the door? I installed a P.O.S. power window kit years ago and had to remove the piece of track on the inside of the door and cut out the stop at the bottom of the door. I now want to go back to an original style regulator. I can fab a window stop but I am not sure about the short piece of track. I am not ruling out just finding a decent set of truck doors and cutting them. My drivers door has some serious rust in the back corner. Both of the doors I have now are cut truck doors.
elkniks is offline   Reply With Quote
Old 07-01-2020, 02:06 AM   #2
randy500
Re: window track inside door
The rear track does bolt in, i have some for sale if needed, send me a PM if interested.
randy500 is offline   Reply With Quote
Old 07-01-2020, 07:03 AM   #3
bigmac73
bigmac73's Avatar
there is a good video on U tube for tearing down and putting the doors back together
https://no-click.mil/?https://youtu.be/RY3yXCjqkZE
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 07-01-2020, 12:19 PM   #4
Davidf
The answer to your first question is yes.
Davidf is offline   Reply With Quote
Old 07-01-2020, 02:43 PM   #5
elkniks
elkniks's Avatar
Yep, I was kind of figuring that since I could not find that piece of track online anywhere. Thanks!
