10-05-2008, 08:52 AM | #1 |
OK,Let's see your steering setup.
I'm still undecided on which setup to use??? Any input (likes & dislikes)will be appreciated,Thanks in advance
10-05-2008, 12:20 PM | #2 |
Re: OK,Let's see your steering setup.
..............Pumps, columns, hoses, gears S/wheels ????
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
10-06-2008, 08:25 AM | #3 |
Yea,I should have been more specific. I want to retain straight axle,already have installed 6 lug power disc setup,tapered bearings,1" tie rods,etc.. Now I need to install a Steering Box & Column. I have a manual box out of later ('77) model truck , but can't seem to make it fit without interfering with front tire.
10-06-2008, 09:58 PM | #4 |
Where does the TOYOTA steering box mount? I've cant get any info on them.
10-06-2008, 10:28 PM | #5 |
I second that question
anyone got a picture ? Gene Shaprp |
10-07-2008, 12:40 AM | #6 |
where the stock box is. they have a simple little mount. check out "no limit engineering" they have pic's of the setup. i think "speedway" also has pic's.
10-10-2008, 08:24 PM | #7 |
I went to both sites and couldn't find any pics?
11-22-2008, 11:11 PM | #8 |
I have a 59 gmc that has the factory 336 in it which I am pulling and dropping in my 60 built 389. But I will probably have to go with the newer GM power steering box that sits on the outside of the frame, since there is no way that I can see that headers will fit between/around the starter and steering box. Any other ideas?
Thanks Robert |
05-02-2009, 02:21 PM | #9 |
Stock GMC Power Steering Unit & Column
05-02-2009, 06:01 PM | #10 |
I wish I had seen your photo three years ago. At least I have an easy solution if the tire interference on mine gets to be a PITA. I ran my stock 59 box with the 4wd front axle using an 80 1 ton van tie rod end to mate it to the stock pitman rod. Same set up will work with the GMC box you have shown. What year range is it?? Thanks
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
05-02-2009, 06:22 PM | #11 |
the stock "factory" ps. boxes are pretty rare these days. the toyota box they use is from a 4x4 79'-85' the solid axle type,the ind. type are cross steering and are wrong for your application. pm me with a phone number and i will be glad to help anyone that needs it.
