High gear ratio w/ M20 & 5.3 Drivability
All,
I have searched and have not found a clear answer to my question. I have a '53 3100 with a S10 frame, 5.3l, Muncie M20 w/ 2.56 1st, 12 bolt passenger rear w/ 2.27 final & tire height ~27". Will the 2.27 ratio that is in my rear cause harm to my truck? I plan to upgrade the rear to a lower gear w/ posi, maybe 3.73, but I'd rather spend my limited funds on getting it running, steering, stopping - can I drive it with this setup until I save for a new rear setup? Will the acceleration be so weak it will be undrivable? As for RPMs, I live in Oregon so speed limits for cruising are fairly low, 55-65mph.
It was said that if you cut off one hydra head, two more grow back. -Lernaean Hydra Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=743246 |
Re: High gear ratio w/ M20 & 5.3 Drivability
2.27?
Where did you find that? |
Now that I think about it it is a 2.29 - but it came with the truck when I got it. It was a pile of parts with a passenger 12 bolt so I was pretty excited until I ran some numbers. I think it came out of a mid 60's Impala or Nova, maybe a 2 speed powerglide?
What’s a couple decimal points between friends! Lol!
Run it. You’ll be turning 2000 rpm at 70 mph. Are you carbed or fuel injected? |
Stock fuel injected, ~250-280 hp (per Wikipedia). I know the top end will be better even with a 4 speed, but time will tell about off the line. Its just going to be a Sunday driver or parts truck, not any performance or racing.
Fabricate till you "puke"
IMHO, you will not like the gearing.....there will be too much slipping the clutch in town traffic
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
The clutch was my main concern, and I'm sure I won't like it. I bet I will drive it some w/ the tall gears, been building for almost two years and once it can move on its own I don't think I could stop myself.
Spending a grand is a tall order (probably on the high side, Randy's R&P prices)- I'll have to start checking eBay & swap meets for deals.
Take-off manners and acceleration won't be what they would with higher gears, but the 2,000 @ 70 is about how that engine would have been set up in a modern 1/2 ton Silverado. Just off the top of my head, 3.73's without an OD will put highway RPM's higher than necessary - 3.07 or 3.42's may be more to your liking. Either way, that's a really fast first to retain good manners over a broad speed range without an overdrive.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
Look around for a used differential....my brother sold a good 3.73, for a 100 doller bill! On that cruiser, you dont need to build a brand new diff.....Pick the one (proper ratio), with no lube dripping. You might do axle bearings & seals, just for pc of mind. But hear is the thing....if you are not racing the truck, you dont need a 9" Ford, or anything built (money)
#10 | |
Last car I built was a G-body with a 454 4-speed and at first 3.08s with 27" tall tire and loved it. Still had plenty to start out, and then could do 70-80 without the tach bouncing off the red peg. Then the ring gear took a couple teeth out and went with 3.42s and didn't like em. Take off was better, but highway sucked. Seemed like it pulled harder with the 3.08s over the 3.42s. But, this was a sorta lite car, so truck with less motor would struggle.
In a truck I wouldn’t go lower than 4.10 or higher than 3.42
At my worst I'm at my best |
This is all great stuff. I’m thinking a big factor is my weight, this truck is light - not much too it. I was pretty set on 3.73, but 3.42 May be the way to go.
I’ll have to keep it to test drives until I get those gears swapped.
Try it and see how it is.
#15 |
Yes weight is a factor but so is the engine. A big block creates more torque at idle (I have a friend that accidentally shifted into 3rd at the stop light in a 427 Nova and it took off with just a little trouble) than a smaller engine which must 'wind up' more to move the weight. So, the gearing will be very important in the equation.
#16 |
driving is in my blood
You'll be fine.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -06 CBR600F4i: 110mph in 2nd at 14,000rpm= happiness. -02 Suburban 4x4: stock DISCLAIMER: I cant spell for the life of me. |
#17 |
Have you tried using this http://www.5speedtransmissions.com/startlineratio.html
