Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 01-12-2018, 08:09 PM   #1
ooimpalaoo
ooimpalaoo's Avatar
1969 c10 hei no spark help
ok so im back ... my poor 69 wont fire it was fine 2 weeks ago. its a inline 250 with HEI i took the coil out and put a meter on it both the primary and secondary coil ar good. i have power going to the cap. ran i hot wire right to it from the batt just to make sure. wtf is going on. what should i check next . took a plug out had my gf turn the truck over as i grounded the threads no spark. what is going on? please please help me . i want back in my truck .
ooimpalaoo is offline   Reply With Quote
Old 01-12-2018, 11:00 PM   #2
Andy4639
Orignal Goof member
Andy4639's Avatar
Thumbs up Re: 1969 c10 hei no spark help
Sounds like the control module went out. When they go out it's done. It sits under the internal coil inside the dizzy.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is online now   Reply With Quote
Old 01-13-2018, 02:12 AM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
I think you can get a module tested at Autozone and if it's bad replace it with a GM Delco
module. Since you have power at the BATT terminal and the coil tests good you may also have a bad pickup in the distributor or the button in the cap might be bad.
HEI modules do not like external voltage regulators because they can generate voltage spikes that can fry the modules. The Delco modules are more resistant to spikes and last longer.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 01-13-2018, 02:17 AM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Just for your info .
https://www.ebay.com/itm/CHEVY-INLIN...item4d4513e0a4
These are obviously off shore but a lot of the members here have bought them with good results and they stand behind them.
VetteVet
Copyright ©2000 - 2019, vBulletin Solutions Inc.
