Old 12-14-2017, 06:09 PM   #1
chris mc bride
chris mc bride's Avatar
carb question
Ok first I'm mechanical fuel injection guy. Haven't run a carb in 25 years. Well 20. I have 454 in 69 panel .Quadramess went bad after sitting for years , so I pulled edelbrock off old 383 sbc that had been sitting lot longer. Bolted it on and runs fine except 2 things. Has a surging issue mainly cold and thats choke issue,but also at low speeds. Rich or lean would cause it to surge some?
Truck still has old sagnaw 3 on the tree so surge shows big time with clutch instead of converter.
Second deal is secondary seems to open later than should.Figure vacuum maybe little lower with new cam xe268 comp cams. Any suggestions on where to start with another spring rate wise?
Hey for carb that set for 20 years and no rebuild its not doing bad,still blows tires off when matting it in first or second,just seems to hesitate pulling those big secondary flys open. Plus need to do away with hesitation for jap crap mad bubble bee punks. Always fun dusting them.
Only the stupid know too much to learn something new.
chris mc bride is offline   Reply With Quote
Old 12-14-2017, 06:12 PM   #2
Coley
Coley's Avatar
Re: carb question
....surging?.....sounds like it might be a vacuum leak which is not uncommon when a carb is changed out.
I would go front to back and side to side everywhere to eliminate that possibility first.
Check every port, every hole, every bolt, every rubber vacuum line....including the power brake line, pcv, etc.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 12-14-2017, 06:22 PM   #3
chris mc bride
Re: carb question
Brake line sounds suspect since been having brakes coming and going,but have had leak and figure air got into system.Will check.Might be open and close deal with engine movement,although small.
Old 12-14-2017, 06:53 PM   #4
Coley
Coley's Avatar
Re: carb question
2 things regarding the power brake vacuum:
1) make sure you don't have an 'open' port on the back of the carb that can be used on some carbs to run the power brakes.
(sometimes they are run off the intake manifold...and sometimes they are connected to the back of the carb)
2) To check if the power brake booster is leaking and part of the problem....simply, carefully clamp the vacuum hose to it with a set of vice grips.
(This same method of 'clamping' all the vacuum lines is actually a good, simple test of that line leaking)
....if your idle settles down then the problem can be within the booster...and I've had this happen to me before, so a booster change was due.
Coley
2000 Dodge Ram 1500
Old 12-14-2017, 07:11 PM   #5
Richard2112
Re: carb question
It does sound like vacuum leak. Another way to check is to spray carb cleaner on the base and linkage while it's running. If the engine speed changes, it's pulling air from somewhere at the carb. Don't catch yourself on fire.
Richard2112 is offline   Reply With Quote
Old 12-14-2017, 08:46 PM   #6
chris mc bride
Re: carb question
Yea have done carb cleaner trick few hundred times. Never had fire but can see where might happen. Brake booster could be issue since both acting stupid.Will see after bleeding lines.Carb cleaner has not shown any leaks yet,will try around lines tomorrow.Either its too cold out or I am getting old,yea its just cold.
Old 12-14-2017, 09:47 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: carb question
Also check your accelerator pump. The Edelpukes have a rubber plunger on a plastic shaft. The rubber plunger part will deteriorate over time. Especially after sitting for awhile they tend to dry out and can get cracks. If ethanol fuel was sitting in it, the rubber part of the plunger will get gummed up. I believe there are plungers that are available that are tolerant to ethanol nowadays.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
GASoline71 is offline   Reply With Quote
Old 12-31-2017, 06:35 PM   #8
crazy longhorn
Fabricate till you "puke"
Re: carb question
Surging....yes, I agree vac leak.I would ask a ? Is it a 1407, or 1411 carb? As far as lower vacumn.....I saw 16-17 inches on my 383(XE268 cam). If you are much lower than that, you may need to tune the ignition. I ran 34 total on my sb @2800-3000, + 10 on the vac can+ plugged to manifold vac source. You may find the BB to like around 36 total....just play. The vac can needs to be cut to 8 -10 degrees (at the crank). my thoughts are that you will be pretty close...(34-36 total@3000+ 8 or 10 on the can). Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
