What are this # on the piston
I bought a couple of 57 trucks one does not run, it was left under a tree for years without the hood and for sometime without the dist., it had a double carb set up and all that rain water going down thru there, this truck has operating air bag system, with a notch on the frame, along with good alum radiator, chrome pulleys, etc etc with that in mind, and because the other truck engine has good amount of $ into it, I believe the truck that is not running might have good brand or quality internals, took the head off and its bad , now I am just wondering what the numbers 05-347-07-c on top of the piston might mean.
2014 cc duramax 2017 king ranch power stroke 57 chevy big rear window, camaro front clip, rear is notched 57 chevy truck, air ride no engine yet, 1947 Chrysler Windsor, all original including the 6 cyl flat head. |
Re: What are this # on the piston
Forgot to even mentioned :
Its small block chevy
Looks like flat-top "double eyebrow" to me but I didn't get anywhere with the number on Google.
Is that a sleeve I see?
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
I know they r 345np .30 but was just wondering what that 2nd set of numbers meant,
Here is the damage
![]() Join Date: Jan 2011
Going by the rust in the port in the head on the other side need to pull it also. looks like the engine may have got rained in. I think the engine is going to need to come out.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
The truck is actually getting a swap, 5.3 6.0 or 6.2 still not decided on which one, i did a 5.3 swap on an 84 about 8 years ago and really loved it,
I just took the head off because my 10 old wanted to see the pistons
The pistons are Federal Mogal hypereutectic coated .
Jimmy
Thanks for the replies,
Happy holiday to everyone
2014 cc duramax 2017 king ranch power stroke 57 chevy big rear window, camaro front clip, rear is notched 57 chevy truck, air ride no engine yet, 1947 Chrysler Windsor, all original including the 6 cyl flat head. Last edited by Slowy-gonzalez; 12-31-2017 at 08:53 PM. |
Thread Tools | |
Display Modes | |
