Old 07-09-2018, 01:33 PM   #1
DieselSJ
Replacement clutch pedal for 87
The pin for the clutch master cylinder rod is wasted. Does anyone know where I can pick up a replacement pedal or pin?
Optionally I have thought about pressing out the pin and threading the hole and using a bolt and cutting off the end of the rod and threading it and installing a spherical joint.
Thoughts?
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 07-10-2018, 04:47 PM   #2
v30crewcab
v30crewcab's Avatar
Re: Replacement clutch pedal for 87
i welded mine up and filed it back to round.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 07-10-2018, 10:52 PM   #3
SunSoaked
SunSoaked's Avatar
Thoughts?
That's exactly what I recently did. Get a 7/16th female rod end. The pushrod is the same diameter as the threaded hole in the rod end. Measure twice- cut once. Cut off, grind smooth and drill a 7/16th hole in the pedal arm. Use a grade 8 bolt about
1-1/4 long and use a locknut to button it up.
SunSoaked is offline   Reply With Quote
Old 07-11-2018, 11:43 AM   #4
DieselSJ
Thank you!! What I'm running into with that idea is the rod on mine is 1/4" (1987) and the pin is 1/2". The only rod ends I can find for 1/4" also only have a 1/4" hole for the pin.
Old 07-11-2018, 02:16 PM   #5
SunSoaked
SunSoaked's Avatar
I see that. Some quick Google search didn't find that size. However, I KNOW they exist as I bought 2 of them sometime in the past. I just gotta figure out where. Might have been Speedway or Grainger. I'll try to find em and let you know
Old 07-11-2018, 06:36 PM   #6
DieselSJ
Looks like new master cylinders all come with rods, so I'm going to let this die. Now I just need to find a replacement pin for the pedal. This is where I may be going with a bolt. Tractor supply has some nice thick wall nylon sleeves so that may work its way into the setup also.
Old 07-11-2018, 06:50 PM   #7
v30crewcab
v30crewcab's Avatar
you'll have to weld the bolt in, you can't tighten it up its got to be able to move.
71 longbed 5.3 4l80
Old 07-12-2018, 01:48 PM   #8
DieselSJ
Bronze sleeve. I can tighten against it.
