Alternator mount rams horns without cast in bosses
I was looking for alternator mounts for aftermarket rams horn manifolds on my 67. Nobody makes them. When I tried spacing out header brackets, I had no adjustment as the bottom mount would hit the bracket, or the adjustment bracket would be to short. I ended up straightening out the header part of the bracket, then bending the top of it about 40°. I now have all the adjustment I need. Hope this helps someone else. Spacers were just under 3/4". Pictures would not load. Rams horns do not have the mount bosses cast in.
Reason: More information
