Old 08-04-2018, 07:31 PM   #1
70K10Hunter
70K10Hunter's Avatar
A/C condenser hard lines
I am having trouble locating the 2 hard lines that come directly off the condenser through the core support. They are short tubes with a rubber isolator, mine are rusted pretty bad. Does anybody know where to find these? these go in my 77 K25.
70K10Hunter is offline   Reply With Quote
Old 08-05-2018, 05:30 AM   #2
Danmcg
Re: A/C condenser hard lines
You'll probably have to make your own if you can't find used ones.
Here's a like to jegs for bend your own lines.
https://www.jegs.com/p/Vintage-Air/V...40747/10002/-1
Danmcg is offline   Reply With Quote
Old 08-05-2018, 01:31 PM   #3
cruizin01
I found mine on eBay used. There seems to be 2 slightly different styles. The one length is not as long as the one you have in your picture.
These were the ones I found.
http://67-72chevytrucks.com/vboard/a...1&d=1525747686
I feel pretty certain I found some new ones after I found the used ones but I've racked my brain and can't remember where.
'78 C10 Build
cruizin01 is offline   Reply With Quote
Old 08-05-2018, 02:02 PM   #4
70K10Hunter
yeh the smaller tube looks shorter than mine, do you know what yr those came off of?
I just found a pair used in Iowa. hope they are the right ones?....
Old 08-05-2018, 02:03 PM   #5
70K10Hunter
I will keep these in mind if the used ones don't work out. Thanks
Old 08-05-2018, 02:06 PM   #6
70K10Hunter
the larger dia tube is right at 12"s and the smaller one is right at 18"s.
Old 08-05-2018, 07:01 PM   #7
cruizin01
The eBay ad said '77.
Worse case if you need to you can do what I did and rebend the line to make it fit. Click through my build for pictures. Post #66
'78 C10 Build
