12-02-2017, 08:57 PM | #1 |
Leaking Fuel Pump - Easy to replace?
The fuel pump on my 72 C20 is leaking, 5.7 V-8. Is this an easy thing to change or am I going to get in over my head? Will gas leak all over me when I change it? Any tips/tricks/comments?
Thanks, Emil 1972 Chevy C20 |
12-02-2017, 09:32 PM | #2 |
Re: Leaking Fuel Pump - Easy to replace?
Easy to change. Lots of Vids on you tube. You will most likely get some fuel on your hands, but nothing major.
12-02-2017, 09:33 PM | #3 |
I bought the 3 line fuel pump for a 5.7 350 V-8, that's correct?
12-02-2017, 10:34 PM | #4 |
For a 72? Or California truck? Mine is just a 2, in and out. Mine is a 70. Just crimp the fuel line coming out of the cab with a pair of vise grips. Should stop the flow. Make sure you get the gasket in, and the pushrod goes back in the way it came out.
12-02-2017, 10:56 PM | #5 |
Junior Member
Sometimes the pushrod will try to fall out. Some guys use a dab of grease to hold it for the few seconds it takes to get the pump in place. If that doesn't work, most blocks have a tapped hole on the front you can run a bolt into that will hold the rod in place while you get the pump tightened in. Just don't forget to remove that bolt afterward.
12-03-2017, 12:29 AM | #6 |
Be sure and check the engine oil for over filled from fuel entering crankcase. Check to see how the oil smells.
'67 GMC 2500, 292, 4spd, AC |
12-03-2017, 12:43 AM | #7 |
Is your original fuel pump mechanical?
Mine was mechanical and it was a breeze. I removed it, cleaned the old gasket area with sandpaper, cleaned that residue off, and used a Carter replacement (mechanical) pump with new gasket. I tightened the bolts back in a little bit on each one to get the thing to seat all over instead of tightening down one bolt and then the other. I watched videos on the process but didn't need to glue the thing down at all. I think mechanical pumps are the way to go. |
12-03-2017, 02:55 AM | #8 |
Moderator
Changing a fuel pump will raise your confidence level as a mechanic, that's for sure. Very easy to replace.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
12-03-2017, 02:59 AM | #9 |
Thanks for the info y'all, I'll be doing it Monday with the help of a mechanic friend.
12-03-2017, 03:00 AM | #10 |
I guess it's a California truck, I have 3 connection pump.
12-03-2017, 05:46 AM | #11 |
I guess California has been more complicated for a long time then.
So you don't just have a mechanical pump on the side of our engine like my 250 does? *Mine is at 9 O'Clock in the pic, the brass-looking round thing. Last edited by In The Ten Ring; 12-03-2017 at 05:54 AM. |
12-06-2017, 02:52 PM | #12 |
I swapped it out Monday night, pretty cool experience! I now know what it feels like to have gas drain on you, haha!
12-06-2017, 02:55 PM | #13 | |
Not sure, mine had 3 lines. One is fuel return, one from gas tank and one is that line that comes up into the engine, carb I think?
12-06-2017, 05:51 PM | #14 | |||
"I ain't nobody, dork."
Gary
12-06-2017, 06:00 PM | #15 |
I went to all the trouble of reaching over my grill and down into the engine bay to change out mine only later to remove the entire front end.........
