Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-02-2019, 09:51 AM   #3101
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2h9kW8j]20190902_094448
now that I have the right patina( 2 years in the backyard), I want to put in a tank and pump so my balls float around the glass housing
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-02-2019, 10:48 AM   #3102
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: PO has me PO'd
Jim
I have to tell ya that that was a disturbing email update to read without the picture there
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 09-03-2019, 09:38 AM   #3103
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
sorry about that, but it would be better than living in a cardboard box in Philly
SAFETY FIRST
AS usual, off topic
Jim
Old 09-10-2019, 11:17 AM   #3104
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2hcZvbE]20190909_095521
[url=https://flic.kr/p/2hcXNrH]20190909_095850
SAFETY FIRST
AS usual, off topic
Jim
Old 09-11-2019, 05:02 PM   #3105
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2he5JEQ]20190911_165500
even the ones with 50 years machining have a bad day, clamping force just was'nt enough,end mill sucked into part, luckily you won't see it
odd shaped part, will redesign with a spacer and machine off all the ugly
This was my third attempt to fit over the timing cover
SAFETY FIRST
AS usual, off topic
Jim
Old 09-12-2019, 09:44 AM   #3106
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: PO has me PO'd
Wow. No injuries then?
Old 09-12-2019, 04:13 PM   #3107
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
No Pete, just my pride and the billet timing pointer! Still looking for a solution, have a sheet metal Mr gasket one in hand, see if I can modify that
SAFETY FIRST
AS usual, off topic
Jim
Old 09-13-2019, 12:30 PM   #3108
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2heRmst]20190913_111230
This may work after all, just have to order some .750 x .250 diameter spacers, give it something solid to pull up on
[url=https://flic.kr/p/2heTW96]20190913_111354
this all can be removed after we establish TDC
SAFETY FIRST
AS usual, off topic
Jim
Old 09-13-2019, 03:40 PM   #3109
litebulblsc
litebulblsc's Avatar
Re: PO has me PO'd
If you are taking the time to put one on there, might as well leave it there. Might come in handy with future diagnostics/ troubleshooting.
litebulblsc is offline   Reply With Quote
Old 09-13-2019, 06:32 PM   #3110
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
I agree, but the installer,said "take it off"
SAFETY FIRST
AS usual, off topic
Jim
Old 09-17-2019, 11:53 AM   #3111
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
SNAFU revision1 part2
mounting flange collapsed, well nuts sucked tank mount down, pictures to follow on evening news at 6 PM...camera batteries low
SAFETY FIRST
AS usual, off topic
Jim
Old 09-17-2019, 12:02 PM   #3112
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Hint Vaporworx.com
SAFETY FIRST
AS usual, off topic
Jim
Old 09-17-2019, 06:51 PM   #3113
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
[url=https://flic.kr/p/2hh2TKq]20190917_184615
Newer in tank pump use a standardized mounting hat, ordered hat trying to contact Carter to get specs on pump #P76088M
Can't believe these well nuts sucked the sheet metal up, bad design on my part
SAFETY FIRST
AS usual, off topic
Jim
Old 09-18-2019, 09:40 AM   #3114
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
cancel search for carter pump...made in China
SAFETY FIRST
AS usual, off topic
Jim
Old 09-18-2019, 09:05 PM   #3115
zicc1835
zicc1835's Avatar
Re: PO has me PO'd
10-4 on cancel the China pump......
zicc1835 is offline   Reply With Quote
Old 09-20-2019, 07:42 AM   #3116
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
yeah, I've got enuff problems without low quality parts, heck they probably stole the blueprints from carter
SAFETY FIRST
AS usual, off topic
Jim
Old 09-20-2019, 10:33 AM   #3117
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
case in point, my fault for buying cheap....
[url=https://flic.kr/p/2hibwpk]20190920_102639
[url=https://flic.kr/p/2hi8ST8]20190920_102744
30 thou. off
SAFETY FIRST
AS usual, off topic
Jim
Old 09-24-2019, 07:50 AM   #3118
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
This is the locking ring and SS mount I picked up from VaporWorx, now I have to figure out how to attach to fuel tank. This seems to be the new industry standard for electric fuel pumps
[url=https://flic.kr/p/2hk9x9E]20190924_074530
SAFETY FIRST
AS usual, off topic
Jim
Old 09-24-2019, 01:12 PM   #3119
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Installer seems to have been able to get quite a bit done, timing done with cam and crank sensors, adjusted valves, and installed poly locks correctly, working on fuel pump purchase, wiring to all sensors, and power to battery and grounds, trans. temp. ran and done, worked on mounting plenum, I was short one bolt.
Also cranked to motor over and got 60 psi up to rockers and push rods, other than the popping thru the 4 missing plugs, he said it sounded good
I lost 3 spark plug wires, in the rush to clean up basement, so the plumbers could install new soil pipe(6" cast iron to PVC)
That's about where I'm at, at the moment, still have to source out a welder to tig the ss mount to the tank, but need fuel pump first to check height
WOW, 400,000 views, seems like yesterday I started this build, it's been a great trip with all of your inputs. Best board on the net
SAFETY FIRST
AS usual, off topic
Jim
Old 09-24-2019, 01:27 PM   #3120
SeventyOne
Re: PO has me PO'd
Hey Jaros - you got a pic of your whole truck? I've bounced in and out of your thread for years but I'm not sure I've ever seen the whole thing!
SeventyOne is offline   Reply With Quote
Old 09-24-2019, 04:00 PM   #3121
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
just the ones at #3090 post, thanks for stopping by
SAFETY FIRST
AS usual, off topic
Jim
Old 09-25-2019, 11:54 AM   #3122
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Here ya go 71, just uploaded, right off the press. read all about it. That's the genius himself, walking under the comp. banner, behind the scenes
[url=https://flic.kr/p/2hkJMA5]20190925_103059
[url=https://flic.kr/p/2hkKvEg]20190925_103035
[url=https://flic.kr/p/2hkKvEr]20190925_103008
SAFETY FIRST
AS usual, off topic
Jim
Old 09-25-2019, 11:57 AM   #3123
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
more...
[url=https://flic.kr/p/2hkKvPE]20190925_103120
[url=https://flic.kr/p/2hkKvRJ]20190925_103143
SAFETY FIRST
AS usual, off topic
Jim
Old 09-25-2019, 12:00 PM   #3124
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
more...
[url=https://flic.kr/p/2hkGW9y]20190925_103204
stage 8 bolt installed
[url=https://flic.kr/p/2hkKvZE]20190925_103219
[url=https://flic.kr/p/2hkKwbG]20190925_103241
SAFETY FIRST
AS usual, off topic
Jim
Old 09-25-2019, 12:01 PM   #3125
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
first oil flow in twenty years, heads can except ol style valve covers or center bolt
[url=https://flic.kr/p/2hkKwda]20190925_104833
these guys are doing the work
[url=https://flic.kr/p/2hkJN9e]20190925_104930
SAFETY FIRST
AS usual, off topic
Jim
