Old 11-10-2010, 04:33 PM   #1
Coreyterry
Coreyterry's Avatar
1980 smog
hello well i finally got my truck, its a 1980 chevy truck. scottdale. c10 2wd light half ton.
will be posting in the projects section later this week.
i have a question regarding smog in California.
it seems the p/o swapped the engine out, from a inline 6 to a 350, however he did not put any smog back on the truck.
my question is what do these truck have on them, smog pump, canister catalytic converter, things of that nature, i have original exhaust but there pretty well toast,
if i could see some pictures of the engine bay and smog equipment i might know better what needs to be put back on.
thanks and i hope i get some quick replys
1967 c20--- traded for a parts truck
1960 dodge d100--SOLD
1980 chevy scottsdale c10---current dd
Coreyterry is offline   Reply With Quote
Old 11-10-2010, 04:56 PM   #2
masterlock
masterlock's Avatar
Re: 1980 smog
I got rid of all that emissions crap and there is a pretty good discussion in this thread http://67-72chevytrucks.com/vboard/s...=421869&page=2
dealing with what is needed for emissions in CA. The pictures are of my truck and I got rid of all that stuff.
masterlock is offline   Reply With Quote
Old 11-15-2010, 02:02 AM   #3
Coreyterry
Coreyterry's Avatar
Re: 1980 smog
ok well been looking at a few california member builds, it seems i am confused on whats what for these trucks, most of the 80's model truck dont have half the stuff ive been told they need, like smog tubes for instance, i was told i needed them, but i havnt seen a single truck here yet with them on there stock before engines?
heres a few of my engine bay,
i can take more if neccecary this is just an exemple, i have no smog tubes and not sure if i even need them. if anyone has pictures of stock engines with all the smog that would be great to look threw.
and thanks master lock your post help a little bit, just still not 100%
Old 11-15-2010, 09:15 AM   #4
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: 1980 smog
That's strange how they left the EGR valve on (although disconnected) but removed everything else. Where those alan head pipe plugs are in the manifold is where the gas recirc tubes would be
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 11-15-2010, 05:44 PM   #5
Mccoleman830
Mccoleman830's Avatar
Re: 1980 smog
Here is my stock 350 in my 78 GMC K-15. hope pics help. Name:  102_0705.jpg
Mccoleman830 is offline   Reply With Quote
Old 11-15-2010, 06:31 PM   #6
Coreyterry
Coreyterry's Avatar
Re: 1980 smog
thanks those pics helped me out alot, a few more questions now that Ive seen yours,
what is this thing, (red circled area)
the red one looks original but the black circled nuts look newish? should i only need three open?
ok and the black circled area with arrow and ? mark, should i have a oxygen sensor on my exhaust? so far i haven't been able to find one on my exhaust system anywhere. i do however have a cat on the exhaust system.
the red area have no holes? does this mean that the black areas are the only ones that need tubes?
Old 11-15-2010, 06:46 PM   #7
sandnuriz
sandnuriz's Avatar
Re: 1980 smog
Get to know a smog guy they are a big help. It pays to go to there shop and shoot the krap with them trust me
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project)
It's your ride build it the way you want !!!!!!!!!!
sandnuriz is offline   Reply With Quote
Old 11-15-2010, 06:47 PM   #8
babyJay
babyJay's Avatar
Re: 1980 smog
Those are the things I mentioned in my first reply! Did you read it?
Jason
89 R3500 CC SRW
Old 11-15-2010, 07:07 PM   #9
babyJay
babyJay's Avatar
Re: 1980 smog
This is the pics of the E xhaust G as R ecirculation tubes on my two 87's, the whole reason I mentioned the EGR valve in my first unread post. Both trucks bypass the #4 & #6 cylinders. Why??? I can't answer that question. Hope this helps.
Jason
89 R3500 CC SRW
Old 11-15-2010, 07:08 PM   #10
babyJay
babyJay's Avatar
Re: 1980 smog
more...
Jason
89 R3500 CC SRW
Old 11-15-2010, 07:09 PM   #11
babyJay
babyJay's Avatar
Re: 1980 smog
And more still...Keep in mind this is an 87 R3500 GMC (first pics) and an 87 V30 (Chevy 4 wheel drive) in the second pics. Not sure where the dividing line is, they seem to be the same under the hood.
Jason
89 R3500 CC SRW
Old 11-15-2010, 07:09 PM   #12
Mccoleman830
Re: 1980 smog
I don't have any 02 sensors on my truck as you can see in my pic. The valve on the right side of the engine you circled i believe is called the Early Fuel Evaporation valve (E.F.E). At least that is what i can find in my 1978 Chevrolet service manual. Looking at your circled pics. It seems that maybe someone has changed exhaust manifolds (but I'm not sure). I've never seen a manifold with two outlets before, just 4 outlets for the air ram system.
Old 11-15-2010, 07:13 PM   #13
babyJay
babyJay's Avatar
Re: 1980 smog
Mine seem to also omit the #3 and #5 cylinders. Maybe mine is not California sanctioned? Doesn't matter to me, they will live and die here in Indiana. It does appear to me that you may have a NON Cali emissions manifold on the right bank though....
Jason
89 R3500 CC SRW
Old 11-15-2010, 07:29 PM   #14
Mccoleman830
Re: 1980 smog
What you should do corey is contact your local smog referee. They can be a huge help when you need them. I found out from mines that my truck was a Cali built truck, and not a federal model. That made a big difference when restoring the truck back to smog legal.
Old 11-15-2010, 07:49 PM   #15
hotrodhomi
hotrodhomi's Avatar
Re: 1980 smog
The sticker on your core supports shows all of the smog requirements. This is what the smog shop will look at and compare your set up too.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 11-15-2010, 08:52 PM   #16
turner16
Re: 1980 smog
What if the sticker is gone?
turner16 is offline   Reply With Quote
Old 11-15-2010, 08:55 PM   #17
babyJay
babyJay's Avatar
Re: 1980 smog
They sell new ones in LMC catalog.
Jason
89 R3500 CC SRW
Old 11-15-2010, 09:20 PM   #18
Mccoleman830
Re: 1980 smog
Smog mines every two years with out the sticker. Never had a problem.
Old 11-15-2010, 09:25 PM   #19
turner16
Re: 1980 smog
do they sell the stickers for other states, other then CA?
Old 11-16-2010, 02:00 AM   #20
Coreyterry
Coreyterry's Avatar
Re: 1980 smog
mine is from the inline six.
i have looked at getting a new one from lmc just dont have the spare change at the moment to spring for one. maybe next month when bills and parts even out for my wallet.
as for the referee, dont even get me started with those people. i called them and talk to a "expert smog person" the only thing he would tell me was that i needed the smog to beable to smog my truck, i asked him if he knew exactly what i needed, he wouldnt give me a straight awnser, so i asked if he knew anyone that could point me in the right direction and told me he couldnt give me personal information about smog information. i think i just got a bad apple but i sure wont be talking to them anytime soon.
some time next week im gonna chat up a local smog shop that seems to be fairly popular, hopefully i talk to the right person and they will help me out.
Old 11-16-2010, 02:04 AM   #21
Coreyterry
Coreyterry's Avatar
Re: 1980 smog
what are you trying to do make me drool haha. how have you been. dont se you around town too much. what side of town do you live on. im here in the s/w we gotta meet up some time so i can check out your ride some more.
Old 11-16-2010, 12:59 PM   #22
sandnuriz
sandnuriz's Avatar
Re: 1980 smog
Coreyterry, Whats up bro? I'm in the sw as well off White Lane & Mountain Vista
Old 11-16-2010, 02:38 PM   #23
Coreyterry
Coreyterry's Avatar
Re: 1980 smog
hey cool, im over off of wible and panama. ill pm you my number and well get together somtime,
Old 11-16-2010, 04:01 PM   #24
terryj
Re: 1980 smog
I just got rid of my smog equipment, installed a set of headers and a new exhaust system. If you weren't so far away I'd say you could have the manifolds and air pump.
terryj is offline   Reply With Quote
Old 11-16-2010, 05:17 PM   #25
Coreyterry
Coreyterry's Avatar
Re: 1980 smog
haha well if i had the money to ship id tell you to send it. but im hurting for money to bad these days, ill get it eventually thow. i talked to a smog guy and hes gonna help me out with my truck. hes gonna show me what goes were and what goes on and what doesnt so hopefully i'll have it back on the road soon.
