07-30-2018, 12:43 PM | #1 |
Active Member
Filler neck grommet
I read all the old threads on installing the grommet without pulling the tank.
Soaked in warm soapy water, sprayed with wd40 and lubed it up with vaseline. It is like trying to put ten pounds of taters in a five pound sack. No luck. Any other tricks or techniques? Thanks |
07-30-2018, 06:53 PM | #2 |
Re: Filler neck grommet
Hi, I’m pretty new to this board but I just replaced the grommet on my C/10 on Saturday. I used a thin premixed spray soap, I believe it was “Simple Green” but 409 or similar would work also. Sprayed the grommet with the soap and started working the grommet into the cab and also onto thriller neck. I also used a very dull old screwdriver to work the grommet into the cab, a little at a time and also to work/push the grommet further onto the filler neck. When the soap appeared to dry up and the grommet started to stick, I’d spray more simple green into the lips of the grommet. Take your time and have patience, it will go!
Russ |
07-30-2018, 07:12 PM | #3 |
Active Member
Thanks.
07-30-2018, 08:02 PM | #4 |
dawn..................
I BELIEVE IN JOHN 3:16 |
08-03-2018, 10:35 AM | #5 |
Active Member
Anyone else, I really do not want to pull the tank
08-03-2018, 12:01 PM | #6 |
pulling the tank is very easy but its best to have a helper. just get it done.
08-03-2018, 12:34 PM | #7 |
I’m looking at this job too. First I have to pull the tank.
Right now I’m getting ready to order a new tank. Any one had a great experience with a supplier, their price, shipping, etc? Will follow the advice above and have a buddy on hand to make the swap. Have noticed that there is a fairly inexpensive tool available to release the guts out of the tank. Seem to recall fighting with a couple screw drivers to get in there one time a long time ago. Any help is much appreciated. Have watched this forum for some time but joined today to get my ‘70 C/10 back on the road. Thanks in advance. Last edited by ACMercker; 08-03-2018 at 12:36 PM. Reason: Clarity of message |
08-03-2018, 09:56 PM | #8 |
I use a plastic pushing tool, you need to get one little bit of the lip fully through the seated, then work it 'round bit by bit .
The grommet is supposed to be very supple ~ cheap Chinese crappo ones that rot and crack in a year, are often very hard and stiff when new .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
08-04-2018, 12:25 AM | #9 |
Active Member
Bought mine from Brothers, pretty stiff.
08-04-2018, 03:52 PM | #10 |
I purchased mine from Classicheartbeat on eBay item # (302819124387) for my 72 C10. It was a little expensive at $17.95 but it has a 100% money back guaranteed or warrantee for 10 years. I just installed it last week with a couple of plastic tools. I spent that much in hopes it won't crack or split. Every year I had to change the cheap ones, hope this one is better. I'll find out in time.
1972 Chevy C10 Cheyenne shortbox/ 350, 3 speed on the floor |
08-04-2018, 10:44 PM | #11 |
Fuel Filler Grommet
Well ;
I looked at the one I installed about three years ago to - day, it's still fairly pliable but has a lot of tiny cracks so I guess it wasn't a quality item .
08-05-2018, 06:31 AM | #12 |
That is where I purchased from recommendations here on the forum. I just haven't got it installed yet.
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
08-09-2018, 10:00 PM | #13 | |
Aaron |
08-09-2018, 10:11 PM | #14 |
I didn't put anything on the one I purchased. It was very rubbery and I got it in with just two plastic tools.
08-10-2018, 03:20 PM | #15 |
there are 2 different filler neck diameters on these trucks and a lot can change in 40 years...so trying to install the grommet for a skinny neck on a thick one would be damn near impossible
1970 short step c10 leaf spring 454 |
09-17-2018, 10:12 PM | #16 |
Active Member
Who makes the best one and where did you get it.
I just picked up a 70 GMC Custom Camper and it needs one. |
09-17-2018, 10:47 PM | #17 |
All about them K’s
I’ve got wes’s (classic heartbeat) Grommit for my truck. Very nice piece. I used Chinese rubber on my 57 and it’s been cracking in different places for a couple years now. I reallly don’t think this one is going to crack.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
09-17-2018, 10:51 PM | #18 |
BlahBlahBlah
09-17-2018, 11:42 PM | #19 |
Wes Hepp @ http://www.classicheartbeat.com/ has helped to produce the best quality grommet.
Mine went on easily in minutes. Use some personal waterless lubrication and a non marring plastic push rod. |
09-17-2018, 11:55 PM | #20 |
Active Member
09-18-2018, 12:28 AM | #21 |
20' Daredevil (Ret)
I got mine from Wes, but won't install it until after the truck is painted. I read somewhere to use silicone grease on rubber products (like hoses). I hope it also works on grommets.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
09-18-2018, 07:59 AM | #22 |
Hi Duke, yes, I got mine from classic heartbeat pickup parts on eBay. I checked it out and they have them. The eBay item # is 302860728432. $17.95 but it comes with a 10 year guarantee. I don't know yet if they are the best, I just put mine in but for that price they better be the best..lol. Also no problem putting it in, just use some plastic tools. Good luck.
