Old 10-30-2018, 11:36 AM   #1
mbzaungst
1972 C10 LWB Georgia Project
Thought I would start a thread about building my truck from just a project. Finding parts and the products I used and things I learned. If it helps someone else great.
mbzaungst is offline   Reply With Quote
Old 10-30-2018, 11:38 AM   #2
mbzaungst
Re: 1972 C10 LWB Georgia Project
Made a couple dollies to move box around on,
Old 10-30-2018, 11:47 AM   #3
mbzaungst
Found a donor turbo 350 from a 1969 c10, had rebuild, new convertor, shot blasted and painted with Aluminum blast from Eastwood.
Old 10-30-2018, 11:51 AM   #4
mbzaungst
Started to weld in door bottoms only to abandon and go to full skins, much easier for the money.
Old 10-30-2018, 11:53 AM   #5
mbzaungst
Found a donor 1972 4 bolt 350 complete for $200
Old 10-30-2018, 11:55 AM   #6
mbzaungst
Sent heads out to have cleaned and shot blasted, cost 50 bucks
Old 10-30-2018, 09:03 PM   #7
zicc1835
zicc1835's Avatar
Nice work .....I’ll be checking in
zicc1835 is offline   Reply With Quote
Old 10-31-2018, 12:49 PM   #8
okndn
good looking build
okndn is offline   Reply With Quote
Old 12-08-2018, 10:14 AM   #9
zicc1835
zicc1835's Avatar
nice progress
Old 12-10-2018, 10:58 AM   #10
mbzaungst
Door jambs and door inner painted this weekend, new seals here today should be swinging by weds. Time to assemble a few things before exterior paint.
Old 12-14-2018, 08:48 PM   #11
cornerstone
cornerstone's Avatar
From these photos your paint work looks great! Did you do all the paint work in your garage or did you use a paint booth? Care to elaborate? I hope I get the courage the spray my truck myself. So far I’ve only sprayed epoxy primer and from what I hear, the final result is all based on the prep work.
cornerstone is offline   Reply With Quote
Old 12-17-2018, 06:41 AM   #12
mbzaungst
Everything has been done in my brothers garage, over spray has been a problem. some cheap painters plastic is a must. Epoxy primers and urethane 2k primers from Omni used. The plan is to use BASF paints and clears, using HVLP guns. a wet floor helps with dust control and wet sanding clears has been a must as well. We have been unable to keep all dust out of the clears. Make sure to drain compressor before paint process and make sure to have good regulators and dryers inline.
Old 12-17-2018, 06:47 AM   #13
mbzaungst
Door seals, doors hung, brakes finished and bled, steering column rebuilt and installed, heater installed, lots of odds and ends finished under truck, hood on for fitment.
Old 01-17-2019, 10:38 AM   #14
zicc1835
zicc1835's Avatar
The workmanship is great I can’t comment on the look until it’s on the truck maybe seem less to those without a keen eye
Old 01-22-2019, 10:55 AM   #15
mbzaungst
This past weekends progress
Old 01-22-2019, 11:08 PM   #16
cornerstone
The grille surround looks amazing.... Is it a new piece? Also the blue looks a bit lighter after the clear was applied. Lovin that color
Brian
1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod.
Old 02-11-2019, 02:11 PM   #17
mbzaungst
Glass installed, door handles, mirrors, dash pad
