08-10-2016, 10:35 PM | #26 | |||||
Re: Bagged woes
I am quite sure that you have been looking into electric leveling systems, hence the multiple valves per wheel and so on. It does not have to be that hard, trust me. About thinking that the valve just dumps the air from the tank, it absolutely does not. When the dump portion actuates, it vents the bag, but closes the supply. Think of it as a SPDT electrical switch, but in a manual pneumatic setting. I hope that makes some sense. Quote:
Also, yes, you set it and forget it. If you add load to your truck, it will automatically compensate and air back up.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292 1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987 Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker |
08-10-2016, 11:57 PM | #27 |
Re: Bagged woes
This thread is great!!!
The only thing I am still struggling with is the whole Normally open vs Normally closed thing. Doesn't normally open mean that it requires pressure on the pilot side to dump the valve? I guess when it comes down to it it doesn't really matter as long as you provide the correct signal via the pilot circuit. For example: http://veritastechsoft.com/dealer_tr...mp-valve-mack/ Am I missing something?
My Build Thread: 59 Apache - Lifelong obsession http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession |
08-11-2016, 09:08 AM | #28 |
Re: Bagged woes
yeah this is a neat solution for sure.
it was my theory (and I havent used this system) that you need a NO valve only because when the truck is dumped using a NC valve means it would have to be energized the whole time its dumped. I could be wrong, which is why I asked for details. the only way I saw it working with a NC was with a second NC valve in line so that when you dumped the pilot air it stayed at zero.
08-11-2016, 09:13 AM | #29 |
Re: Bagged woes
59 chev...A normally open valve is a valve that in its non operating mode is fully open and requires constant power input to close it.take power awayand it goes back to full open..a normally closed valve works just the opposite..its fully closed until you supply constant input power to open it..take power away and it goes back to a closed position..
08-11-2016, 11:25 AM | #30 |
Re: Bagged woes
I agree that the ideal situation is to remove the pilot air in order to signal the dump valve to dump the air. What I'm confused by is in researching these valves, the description of Normally Open says it needs air to dump.
This seems opposite to what everyone is saying based on the description of normally open See attached image of the valve I linked to.
08-11-2016, 11:32 AM | #31 |
Re: Bagged woes
oh I see what you are asking. it was oneoffstroker that said flipping the switch REMOVES the pilot air, so that was the assumption I worked with. looks like the valve you found works the other way, requires pressure to dump.
this adds a wrinkle to finding leaks in the system, because if you lay it out and have a leak in the pilot system, you may come out in the morning and find your truck at ride height which to anyone who has had an airbag system, thats a good problem to have because usually you find it flat on the ground with no air in the system
08-11-2016, 11:57 AM | #32 |
Re: Bagged woes
Yeah that don't sound right..requiring pilot pressure to open a valve means the valve has to be normally closed ..take away the pilot pressure and the valve closes..
08-11-2016, 09:42 PM | #33 | |
Re: Bagged woes
I hope someone else adopts this system for their truck. It's pretty legit.
08-11-2016, 11:19 PM | #34 | |
Re: Bagged woes
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
08-11-2016, 11:56 PM | #35 | |
Re: Bagged woes
Thanks again for posting this idea!!
My Build Thread: 59 Apache - Lifelong obsession http://67-72chevytrucks.com/vboard/showthread.php?t=622133"]59 Apache - Lifelong obsession Last edited by 59chev; 08-12-2016 at 12:06 AM. |
08-29-2016, 07:47 PM | #36 |
Re: Bagged woes
Just ordered my valve, should have it tomorrow. Sence I'm only bagged in the rear I really liked this idea. I will let everyone know how this works out.
08-29-2016, 11:54 PM | #37 | |
Re: Bagged woes
Cool!! Really interested to hear how this works out.
08-30-2016, 09:33 PM | #38 |
Re: Bagged woes
08-30-2016, 09:40 PM | #39 |
Re: Bagged woes
08-31-2016, 12:50 AM | #40 |
Re: Bagged woes
great video! thanks for posting!
08-31-2016, 02:23 PM | #41 |
Re: Bagged woes
08-31-2016, 02:40 PM | #42 | |
Re: Bagged woes
I bought mine local, but this is the valve I used. |
09-01-2016, 04:02 PM | #43 |
Re: Bagged woes
ADchevys, great video and pic. I'm glad I was able to convince at least one person to try this setup! Maybe if it gains popularity, I can be the namesake for the mod. lol Like, 'Stroker's Manual Ride-Height System' or something like that.
LS267GTO, here is the valve I used when I did mine. http://www.ebay.com/itm/310636490872...%3AMEBIDX%3AIT
12-16-2018, 06:16 PM | #44 |
Re: Bagged woes
Old thread but really like this. Any updates on functionality
12-16-2018, 06:37 PM | #45 |
Re: Bagged woes
haldex valve with pilot port
this is usually "aired up" in order to dump the air springs. truckers use this to lower suspension so they can back under the trailer they are connecting to. less time and energy spent cranking the trailer dolly legs up. https://www.haldex.com/globalassets/...ols/l31186.pdf |
12-17-2018, 08:49 AM | #46 |
Re: Bagged woes
dsraven, can you send me some pics of it installed in the front. really considering it. like the simplicity and really seems like a reliable system
thank you |
12-17-2018, 08:53 AM | #47 |
Re: Bagged woes
Also, if running these at each corner would making a manifold for the dump valve be functional (i just want one dump valve in the cab). How much psi is needed at the pilot dump is what I'm asking pretty much. thanks again
12-17-2018, 02:04 PM | #48 |
Re: Bagged woes
I don't have a pic, I have just worked on the big trucks that use this type of system. they are used for everything from air ride cabs to truck suspension or trailer air ride.
for a manifold, yes, you would simply need a dump valve on the dash or wherever that would supply system air (greater than 60 psi and up to 130 psi) out to a manifold that would run to each valve. an electric solenoid valve would also work so the air lines could stay outside the cab and just have wire run to the dump valve from an in cab switch. from there T off and run a line to the front, where it could T again to each side valve, and then the same for the rear. less air line equals less air required to fill the lines so running an air line from each valve to the manifold would take more air and also more room. less air line would mean a quicker response and less compressor run time. a larger line to the front and rear could be T'd at each end to smaller line for each valve if you think it warrants that. sometimes a slower dump is better. you could also do a dual system so you can dump just the front or the rear. this is what you see city busses do when they "kneel" for handicap access. but thats up to you and your wants/needs. these valves would be available online or at your local highway truck parts shop. even some truck stops may have them. pretty common valve because lots more big trucks are air ride these days, but, you could also ask at the truck parts place if there is a more common valve. just a bit of time on the phone. hope this helps. here is a link to the haldex site which shows a bunch of control valves. http://www.heightcontrolvalve.com/haldex-19.htm here is a link explaining the normally open or normally closed dump valve options and how they work http://www.plazafleetparts.com/air-s...ol-valves.html |
12-17-2018, 02:09 PM | #49 |
Re: Bagged woes
another thing to watch for is where to mount the valves. a single valve mounted in the middle of the axle could do the whole rear end but not be specific to each side. less messing around with getting them syncronized so one doesn't fight the other. if you need room for rear dump exhaust pipes or whatever then that may also dictate the valve mounting and air line routing. always try to cover the plastic line with something to stop chaffing unless it is tied down well. some heat shielding may also be required if close enough to exhaust systems.
