10-23-2003, 07:57 PM | #1 |
Remove and replace dash pad
Can someone tell me how to do this.
Please
Joe Peters the HatGuy 72' K5 Highlander My Daily Driver http://www.pbhats.com/BLAZER/index.html |
10-23-2003, 08:45 PM | #2 |
Pull your glove box out. If you already have a new dash pad replacement you will see the threaded pegs that hold it in place. This will give you a good idea of where they are. Start undoing the nuts. Work your way across. Depending on how nimble you are you might have to pull the radio and the guages. It has those thin self cutting nuts like what some emblems have so you will need to get square on them. Pretty simple hope this helps
10-23-2003, 10:30 PM | #3 |
Thanks Pound41
10-25-2003, 03:58 AM | #4 |
any other advice?
anyone?
10-26-2003, 11:26 AM | #5 |
Wish I could help, but i gotta do the same thing. Email me with results. Think of it as a courtesy to an exiled fellow Texan. I call Flower Mound home.
'72 Blazer, 4WD, 350/4 spd. Affectionately known as "Da Beast" '04 Silverado (new daily driver) '00 Intrepid (wife's ride) It's a BLAZER dude! No options, no emblems, no a/c, no fancy shmancy. It's a BLAZER.... |
10-27-2003, 03:47 PM | #6 |
Sure helps to have the gauge bezel out too. They couldn't make them more difficult to get to!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
10-27-2003, 04:06 PM | #7 |
The Blazer King
I had to pull the Golve box, dash bezel & Light switch. Radio would be helpful to remove.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
11-11-2003, 02:58 AM | #8 |
Everbody has probably already got all of this dash pad business figured out but here's my tid bits of info.
If I recall correctly, there are four phillips head screws going through the dash pad into j-nuts on the lower side of the dash pad. On the firewall side there are nuts threaded onto the studs that are protruding through the dash sheetmetal from the pad. I do not remember the qty, but at least five. A couple of them are really hard to get to. The ones on the ends of the pad and the one by the wiper switch come to mind. Anyway, hope some of this helped.
Be wary of the light at the end of the tunnel....It might be a gorilla holding a flashlight! 71 Blazer, ex-4WD...Bought it that way 55 GMC 55 Belair 2dr HT 67 El Camino |
11-11-2003, 01:25 PM | #9 |
SKINNY TIRES RULE!
Like everyone else said, pull the cluster and glove box. I'm sure it will help to pull the radio, but I can't speak from experience on that since I don't have a radio (just a big hole thanks to a PO). It's also a good time to make sure all your wiring under the dash is nice and pretty too.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
