Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 08-22-2019, 02:25 PM   #1
weq92f
What does this mean...
While under full load and full texas heat...
If I measure 13.3v at battery + and - posts, then measure 13.7v at battery + and alternator ground post, what accounts for the difference?
Thank You!
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 08-22-2019, 04:05 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: What does this mean...
Resistance?
Old 08-23-2019, 09:53 AM   #3
SunSoaked
SunSoaked's Avatar
Originally Posted by The Rocknrod View Post
Resistance?
SunSoaked is offline   Reply With Quote
Old 08-23-2019, 11:17 AM   #4
weq92f
I'm asking the question because I really don't understand what is happening.
Based on your responses, I'm going to assume then that the difference is simply the higher voltage at the alt.
What I am not following properly is exactly how my measurement can change by simply moving the ground point from the battery to the alt? This must be Electrical 101 then, yes? Are we not in the Electrical section of the Forum?
-klb
Old 08-23-2019, 12:49 PM   #5
The Rocknrod
Moderator
Resistance - https://science.jrank.org/pages/2335...esistance.html
And it's probably not a straight shot from the alt post to the battery so that adds to some loss.
Ohh and where the alternator "reads" the voltage makes a difference, where the (usually white) wire is attached in the system. If it reads it close to the alt then at distances farther away like the battery may be a lower voltage as well.
Old 08-23-2019, 01:03 PM   #6
weq92f
OK thanks, I understand voltage drop and the sensing of the multi-wire ( original ) alternator and how the internal regulator works. BTW, my alt in this case is a single wire unit.
What I'm asking about is why I see a different voltage on my meter while leaving the positive probe on the positive battery terminal at the battery and then touching the negative probe to two different places: 1) negative post on the battery ( 13.3v ) and 2) the ground post on the alternator ( 13.7v ).
That seems counter intuitive to me.
I'm not touching the alternator output post at all, not directly. I'm only using the ground post on the alt to complete the circuit as far as the DMM is concerned.
I'm showing my ignorance here,
-klb
Old 08-23-2019, 01:05 PM   #7
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What does this mean...
This is basic electrical stuff.
Read through this page it will help you understand.
http://www.madelectrical.com/
The alternator puts out what it needes to keep the truck running. It doesn't put out the max voltage if it did your battery would explode. The system draw determines how much it sends to the battery to keep up with demand of the system.
Take your meter and put it on a hot wire on the fuse block inside the truck and ground it some place and see what it's reading with all your stuff on. This will give you a good reading of what your alternator is doing and if it's less than 13 volt's at idle you need some work done to the electrical system.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 08-23-2019, 10:32 PM   #8
Wrenchbender Ret
Try grounding the wire to the frame of the alternator. It shouldhave the same reading as with the ground on the battery. If not you have some resistance in the bat. cable ton the engine or the alternator mounting to the engine. If it is different from the terminal you must have resistance in the ground term. to the alternator case.
George
Wrenchbender Ret is offline   Reply With Quote
Old 08-23-2019, 11:49 PM   #9
truckster
truckster's Avatar
The answer is electrical resistance - the voltage is being produced at the alternator, which is where you're reading 13.7 volts. When you measure at the battery + terminal and the alternator ground, you're shortening the route the current has to travel. When you're measuring at both battery terminals, the current has to travel farther. Depending on where your battery ground is, the current has to travel through the alternator bracket, possibly through the block, through a lug and into a copper wire, through another lug and into the battery post. All of those add some resistance. If any of those points are dirty or corroded they'll add more resistance.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
