08-18-2018, 03:33 PM | #1 |
1954 3100 mii
anyone running a MII IFS on their 47-54? I am real close to buying one from a dealer in Iowa. seems better than the too many probs with clips ect.
08-18-2018, 09:02 PM | #2 |
Re: 1954 3100 mii
Yep!
08-18-2018, 11:09 PM | #3 |
Re: 1954 3100 mii
subframing is old school. it works but it causes a lot of extra work down the road. clipping works but I will never do it again. cross member kits while a bit more costly give far more in terms of ease of installation and technology to go back to clipping. make sure to use a reputable brand and you will be all smiles.
08-18-2018, 11:26 PM | #4 |
Re: 1954 3100 mii
I'm running one on my 50, it has 27,000 miles with no problem. Like stated above, buy a well know unit...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
08-19-2018, 02:36 PM | #5 |
Re: 1954 3100 mii
I have a crossmember, control arms, and spindles still in the box awaiting fitment in my 3600. I bought the pieces from different vendors. I was trying to be budget conscious. Hindsight, I wish I would've bought all from the same place.
There are a couple different widths for crossmembers, mine is the narrow one. Also some vendors use a cheaper lower ball joint, be aware of that. The crossmember is an "economy" unit from CPP. It's 3/16 steel and the build quality is excellent. My only complaint is that it's the narrow version. Like I said before, I wish I would've bought everything from them. |
08-20-2018, 12:21 AM | #6 |
Re: 1954 3100 mii
I'm using one from NO LIMIT ENGINEERING w/ Ridetech coilovers....Its a very nice kit
08-20-2018, 01:28 PM | #7 |
Re: 1954 3100 mii
Just a thought, give JW Rod Garage in Belgium, WI a call. From what I understand they build their stuff in house. I haven't heard anything bad about them either.
08-21-2018, 07:04 PM | #8 |
Re: 1954 3100 mii
TY all!
08-22-2018, 09:19 PM | #9 |
Re: 1954 3100 mii
I used one from TCI, there is pictures of it in my build
