Old 04-03-2018, 09:38 AM   #1
ChadW
SBC 327 history
I got a sbc 327 with a project i bought and was told it was a factory 300hp 1964 out of the Tonawanda NY plant. I got some numbers off the rear of the block (near where the tranny mounts up. Can i verify what i was told by any of these numbers?
3858180
D3064
6T
C0NV1
ChadW is offline   Reply With Quote
Old 04-03-2018, 10:58 AM   #2
geezer#99
geezer#99's Avatar
Re: SBC 327 history
Your casting number 3858180 shows it’s a 64-67 327.
http://www.mortec.com/castnum.htm
You’ll need the suffix code off the pad in front of the passenger side head to narrow it down.
Old 04-03-2018, 08:54 PM   #3
ChadW
Re: SBC 327 history
Its T05I9S. And I can’t find anything with a 9S suffix code...I was told originally this is a 327/300 motor that was built in the Tonawanda plant when the Flint plant went on strike in 64 and its out of an impala...unless I’m looking in the wrong places, I can’t find any suffix codes close to what I have...of course...lol
Old 04-03-2018, 09:34 PM   #4
geezer#99
geezer#99's Avatar
Re: SBC 327 history
T——Tonawanda
0519—May 19
S——look here.
It says 1962 327.
Look a little closer to see if there’s another letter after the ‘S’.
Sometimes all the info from different sources doesn’t match.
http://www.nastyz28.com/gm-chevy-cod...s-suffix-6.php
Old 04-03-2018, 09:37 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: SBC 327 history
NastyZ28 is my go to for engine and parts decoding. Mortec is just too broad, where NastyZ28 has a bit more info.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-03-2018, 09:42 PM   #6
ChadW
Re: SBC 327 history
T——Tonawanda
0519—May 19
S——look here.
It says 1962 327.
But the casting number 3858180 says 64-67 327....??
Did they sometimes use an i instead of a 1 as its clearly an upper case I as well
Old 04-03-2018, 09:53 PM   #7
ChadW
Re: SBC 327 history
T——Tonawanda
0519—May 19
S——look here.
It says 1962 327.
Old 04-03-2018, 09:58 PM   #8
YoungPup1977
Re: SBC 327 history
180 casting..... with a casting date of april 30 1964....
T0519S = may 19 1964
so with the suffix code of S.....(you need another letter). "SL" maybe.....
Clean the area on the block real good where you got T0519S and take a pic of it and post it. Thanks.
YoungPup1977 is offline   Reply With Quote
Old 04-03-2018, 10:06 PM   #9
ChadW
Re: SBC 327 history
Click link to see pic... I read it as T05I9S
dropbox.com/s/11zv38iknnx4ujn/20180403_194001.jpg?dl=0
Old 04-03-2018, 10:12 PM   #10
YoungPup1977
Re: SBC 327 history
I can not see it....post a pic without the dropbox link thanks
Old 04-03-2018, 10:16 PM   #11
ChadW
Re: SBC 327 history
Only way I can tonight...click link then choose continue to website and it will open pic with no need to install dropbox
Old 04-03-2018, 10:24 PM   #12
ChadW
Re: SBC 327 history
Old 04-03-2018, 10:25 PM   #13
ChadW
Re: SBC 327 history
Old 04-03-2018, 10:25 PM   #14
YoungPup1977
Re: SBC 327 history
I will look tomorrow for another pic, take it as close to the letters as possible without distorting the letters........thanks.
Can you take all the orange paint off before the pic....maybe a letter is hiding under all that chevy orange...Thanks again.
Old 04-04-2018, 01:50 PM   #15
61K10
61K10's Avatar
Re: SBC 327 history
the block casting date D3064 (4-30-64) is fine for a may 19 build. Not having the org heads and intake it's just a non stock engine.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-04-2018, 05:08 PM   #16
YoungPup1977
Re: SBC 327 history
3858180
D3064
6T
C0NV1
Going back to your very first post:
with the information you are providing, there is NO WAY to agree with the 300HP 327 information you were told....GOOD LUCK !!!!!!! Did your camera break just after you took the first pic....
Take the paint off and take a pic and post it.....
