Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 02-16-2018, 06:57 PM   #1
bestchevyfan
Help--turn signals
1968 chevy== all my lites,brakes,turn signals were working.i put l.e.ds. In them all and now the turn signals dont work. It was two new flashers to use with the kit i replace the one in the fuse box.where does the other one go ? Thanks,buddy
bestchevyfan is offline   Reply With Quote
Old 02-17-2018, 09:43 AM   #2
toiletbowl54
Re: Help--turn signals
I know nothing about a 68 electrical system,do you have emergency flashers in your 68? If so that is where the second one goes. Do you have a wiring diagram of your truck if so look at that or see if one is available on this site. Just some thoughts.
toiletbowl54 is offline   Reply With Quote
Old 02-17-2018, 11:32 AM   #3
MIKESAD50
swap the wires on the turn signal flasher and try that. Had the same issue on my build with new harness though. also other flasher could be 4 ways, depending on how wired.
1950 3100 5 window
MIKESAD50 is offline   Reply With Quote
Old 02-19-2018, 01:54 PM   #4
Wrenchbender Ret
Put a jumper wire in the 2 terms were the flasher plugs in. The turn signals should work this way except not flash. Make sure both flashers are plugged in at the fuse panel. You may just have the 4 way plugged in.
George
Wrenchbender Ret is offline   Reply With Quote
