Old 03-19-2015, 10:52 PM   #1
russellrox
Where to buy best wiring harness for 63 c10
I am wanting to install all new wiring into my old truck, I am also wanting to do a LS1 or 5.3L swap with a 4L60E trans, is there a harness that I can buy that bolts right in and works for these trucks. Or do I have to buy the chassis harness separate then do a different engine harness, I want it to be plug and play pretty much If I'm spending the money.
russellrox is offline   Reply With Quote
Old 03-19-2015, 11:59 PM   #2
BigDan3131
BigDan3131's Avatar
Re: Where to buy best wiring harness for 63 c10
I plan to use a complete kit from Ron Francis Wire Works. They have more options when it comes to the fuse boxes and instead of having it all connected to the fuse block you run the wires up to it to minimize the extra wiring harness that gets built into other companies stuff.
Link: http://www.ronfrancis.com/
The other thing I like is they will customize it to suit your needs and the charge wire to your alt is much larger than stock.
Custom Painter/Restoration Specialist focusing on all American made vehicles from 1948-1974.
1965 GMC 3/4 Ton LB
1964 Chevy El Camino 11.83 1/4 mile time in 1990
1991 Chevy S10 248K+ miles 2nd Owner
BigDan3131 is offline   Reply With Quote
Old 03-20-2015, 04:57 AM   #3
Thiessen1960
I am going to go with the American Autowire Kit specifically made for our trucks. I had a friend use one and he loved it and also have read excellent reviews on it.
Thiessen1960 is offline   Reply With Quote
Old 03-20-2015, 06:42 AM   #4
PGSigns
PGSigns's Avatar
I have the American Auto wire setup in my 65. I used the classic update kit. It is very complete and well thought out. It has the power and available fuses for engine swaps. Plug and play will depend on the engine/trans harness you get for your ls setup. I am just starting the ls swap into the 65 and I dont see any issues with the AAW interface.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-20-2015, 11:52 AM   #5
Dannyego
check out rebel wire. Made in the US labeled great and heavy gauge. I wired my 56 with it and plan to use one in my 64. Really cant be beat.
Dannyego is offline   Reply With Quote
Old 03-20-2015, 02:29 PM   #6
vin63
It's Better With Nitro
vin63's Avatar
From someone who used to build my own wire harnesses, I've since used Ron Francis products almost exclusively.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-20-2015, 02:42 PM   #7
TJ's Chevy
Chevy I6 and GMC V6 Nuts
TJ's Chevy's Avatar
American Auto Wire classic update harness I've heard alot of good about. Cheapest I found it for was $494 but its a great system.
"6 in a row makes it go!"
"I prefer a buzzin half-dozen"
Old 03-21-2015, 01:56 PM   #8
DLW
Ron Francis here as well..
DLW is offline   Reply With Quote
Old 10-31-2018, 10:59 AM   #9
birch motor cars
birch motor cars's Avatar
I ordered from Rebel Wire (made in the USA ) You can actually pick up the phone and talk to the guy that made your harness and will be available for any questions during your install if needed. I ordered direct from Rebel vs mail order because I wanted to talk to someone that knew something. I spent a lot of time researching what to buy and so far I am very happy with the Rebel product. Cost wise they are a lot less then everyone else. Every wire is clearly labeled and the directions are very easy to follow. Do yourself a favor if you haven't ordered your wiring yet call this guy and Im sure you will like what you find out.
birch motor cars is offline   Reply With Quote
Old 10-31-2018, 02:08 PM   #10
Macdaddy1
Ordered american auto wire classic also. Have yet to install it yet.
Macdaddy1 is offline   Reply With Quote
Old 10-31-2018, 02:53 PM   #11
Clyde65
Clyde65's Avatar
AAW Classic update, have installed 2, easy and great product.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-31-2018, 04:07 PM   #12
The Rocknrod
Too Cool For School
The Rocknrod's Avatar
I bought a generic unit with xtra long wires to fit my truck. I always seem to have to modify them anyway. I like wiring and dont like doing things someone else does usually.
Having said that I like what American Auto Wire has to offer.
Master Chief, US Navy, Retired - He ain't no drag Papa's got a brand new bag
1964 C10 Step-side Short Bed - In Progress
2009 2500HD Duramax LTZ
1948 GMC Panel
1956 Big Window Stepside
1953 5 Window Chevy Stepside
New Seat Foam for Bench Seats?
Old 11-01-2018, 02:27 AM   #13
gmcdeadhead
gmcdeadhead's Avatar
ive bought and installed the american auto wire, i would buy another ,
gmcdeadhead is offline   Reply With Quote
Old 11-06-2018, 08:28 AM   #14
Cohi
I usually buy a speedway kit and remove any circuits I won't be using to eliminate any extra wires. Pretty simple, clear instructions, wires are labeled like other manufacturers kits.
I incorporate a junction block in the engine compartment somewhat following the examples provided in the tech section of the mad electrical site and I add relays for the headlights. Simple alterations.
Cohi is offline   Reply With Quote
Old 11-06-2018, 10:46 AM   #15
Clyde65
Clyde65's Avatar
Mcbmatt in the market place sells the AAW harness for very reasonable
Clyde65
Rebuild of Clyde
support our troops!
Old 11-06-2018, 02:44 PM   #16
pdxhall
pdxhall's Avatar
I've got the AAW classic update kit and I'm in the process of installing it right now. This is a very nice kit.
Sanity'66
http://67-72chevytrucks.com/vboard/s...d.php?t=515110
Long bed, Fleetside, Small back window
I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing.
pdxhall is offline   Reply With Quote
Old 11-10-2018, 12:41 PM   #17
roll_the_dice
roll_the_dice's Avatar
I also recently bought AAW kit for my 65. I am about to start installing it. Everything is labelled inside the box and makes it look less daunting.
roll_the_dice is offline   Reply With Quote
Old 11-14-2018, 06:40 AM   #18
REDROCKER652002
My son and I just finished using the AAW Kit for his 1969 stepside. It was a complete kit including the cab wiring, engine and front and rear taillights. Easy and the customer support was awesome. Only thing I would add is get the crimping tools they offer to rent. It makes crimping the connectors easy and a standard crimper will only mess things up. Don't ask how I know. LOL. But, I have nothing bad to say about the company or the product.
Dino
REDROCKER652002 is offline   Reply With Quote
Old 11-15-2018, 10:32 AM   #19
Pontitruck
Pontitruck's Avatar
The Psi Conversions kit came with my project. When I start wiring I’ll let you know how theirs is. If anyone has tried it please proceed feedback. Thanks
Well, I'm an idiot. The PSI conversion portion I have is a standalone harness for an LS transplant. This is the PCM programming and bracket kit. I have the AAW kit for the rest of the truck.
Pontitruck is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
