12-28-2019, 08:16 PM | #1 |
Radiator mount
Hey guys! Wanted to flush my radiator this weekend. Started draining some really rusty/muddy looking stuff and noticed that the radiator was sitting on a pice of 2x4 held in place by bailing wire and two pieces of wire wound around bolts up top.
I know it’s been 40 years but pretty sure this wasnt OEM set-up. Not to mention that the shroud has a piece missing held together with zip ties. Bottom line, unsure if radiator is correct for the truck. Kind of think so. How should this be mounted in my 79? Any pics, diagrams, or info to point me in the right direction?
1979 C-10 LWB |
12-28-2019, 09:12 PM | #2 |
Re: Radiator mount
you have a short height rad in a tall rad setup .
get short rad upper brackets or newer rad for tall option . . . . or leave it alone . i ran a short with a 2x4 and a small strip on top to keep it from kicking out for a few years and no problems.
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
12-29-2019, 01:14 PM | #3 |
Re: Radiator mount
A cheap way to flush a radiator is pour the home depot version of clr into it, and let set for a hour I think.
Not as good as a new radiator but alot better then just water. |
12-29-2019, 05:04 PM | #4 |
Robert Olson Transport
Re: Radiator mount
the first question is the core support good? theres supposed to be a couple of rubber things for it to set on and if you want me to take pictures of mine let me know and ill gladly post em up
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
12-29-2019, 05:12 PM | #5 |
Re: Radiator mount
Ore support seems to be solid. I think that I am missing parts, possibly rubber stops/rests for the bottom to sit. Also, a top plate or mounting brackets to connect it to core support.
Unsure if shroud is the right one or something rigged up.
1979 C-10 LWB |
