09-06-2018, 11:14 AM | #1 |
305 to 350 motor swap question
I am going to be putting in a 350 motor that will replace my 305 in my 85 GMC. I need to get some new pulleys as some of the ones on the current motor are not the original equipment. I need to order a water pump pulley and a crank shaft pulley. In the LMC catalog, they offer 2 & 3 groove crank pulley and a 1 & 2 groove water pump pulley. I will be running A/C and need to know which combination of the two that will work together. I called LMC and they didn't offer much help. Can anyone help me with this?
Thanks, Rick Last edited by rikoshea83; 09-06-2018 at 11:51 AM. |
09-06-2018, 01:13 PM | #2 |
Re: 305 to 350 motor swap question
I recently pulled my original drive system off my 85 (350) w/ factory air. Here's a pic of it before it all came off (minus a/c). If your interested in it, let me know. Complete OEM system (upper/ lower pulley, alternator, ps, ac brackets).
09-06-2018, 02:50 PM | #3 |
My 75 with 350 and PS/AC has a 3 belt main, 2 belt WP, 2 belt PS, 1 belt AC, and 1 belt Alt.
AC belt also runs in 1 of the PS grooves. For extra fun, the main has 2 the same and 1 larger. The WP has 2 sizes as well. Mine has the older style long AC compressor instead of the newer pancake version. |
09-07-2018, 09:42 AM | #4 |
What do you want for it?
09-07-2018, 02:02 PM | #5 |
LMC can get expensive. I just did a motor swap and got a lot of parts from rock auto and amazon. Just FYI. Good luck on your swap!
Jeff |
09-07-2018, 02:30 PM | #6 |
09-08-2018, 10:19 AM | #7 |
09-11-2018, 08:36 AM | #8 |
09-12-2018, 07:39 PM | #9 |
It's on the way.
Thread Tools | |
Display Modes | |
