Old 08-01-2018, 08:48 PM   #1
Geos 72
Geos 72's Avatar
Lowering
Hello to everyone. I need a little advice. I'm thinking of lowering my 72 C10 2" in front and 4 in the rear. I have coil springs all around. Could I do it with just lowering springs and shocks or would I need all the rest of the parts like c-notch , brackets and shock relocators and what ever else? I heard you would need all those other parts only if you lowered it more than 4".
1972 Chevy C10 Cheyenne shortbox/ 350, 3 speed on the floor
Geos 72 is offline   Reply With Quote
Old 08-01-2018, 09:04 PM   #2
SC1969c10
From what ive read up on your right with the extras being required past 4. Im interested to see some others chime in as my trucks 2 in the front right now, stock out back.
SC1969c10 is offline   Reply With Quote
Old 08-01-2018, 09:07 PM   #3
HO455
HO455's Avatar
Re: Lowering
For the amount of lowering you want I would go with 2" drop spindles in the front and 2" drop blocks with 2" springs in the back. This will allow you to maintain the most of the factory suspension travel giving you better ride quality.
Now the caveats. New spindles may mean a shift to disc brakes, but you could reuse your front springs. Some 15" wheels won't clear dropped spindles. Plus you will loose some ground clearance under the spindles and trailing arms. There are lots of threads on dropped spindles on the board. C notch is not required for 4" in the rear using blocks.. Shock relocation won't be necessary in the front but a good idea in the rear as the factory set up isn't optimal. That being said you could do the drop blocks and spring approach and see how it rides. Then if you're not satisfied then you can rework the shock mounts. The angle of the rear shocks gets greater the lower you go and the shocks ability to dampen the axle movement is reduced.
RIP Bob Parks.
1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo
Old 08-01-2018, 09:08 PM   #4
AirSpeed
AirSpeed's Avatar
I lowered my 69 C10 4 and 3 with just springs and new shocks, no issues at all
AirSpeed is offline   Reply With Quote
Old 08-01-2018, 09:14 PM   #5
ZEKE68
ZEKE68's Avatar
Re: Lowering
I am running 2 1/2" drop spindles in front and 4" drop coils in the back with no frame notching. I still have around 3 1/2" travel before the rear axle touches the rubber bumper. Don't see why you would need to notch at 4" drop unless you carried loads in the bed.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 08-01-2018, 11:09 PM   #6
SC1969c10
Got a photo?
Old 08-01-2018, 11:43 PM   #7
Geos 72
Geos 72's Avatar
Re: Lowering
I forgot to mention that I have disk brakes in the front. I don't have much cash to play with so maybe I'll just try the lowering springs and shocks and see how that goes or just leave it the way it is. Thanks everyone, I appreciate the advice and help.
Old 08-02-2018, 09:55 AM   #8
ga-stepside
ga-stepside's Avatar
Re: Lowering
I am running 2 1/2" drop spindles and 4" lowering springs in the rear with shock relocators. No problems. I have 18" rims with 255-60-R18 series tires on the front and 265-60-R18 on the rear.
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 08-02-2018, 11:18 AM   #9
demian5
demian5's Avatar
Re: Lowering
I went 3/4 with this kit using 3" springs and a 1" block. Never bottoms out, no bumpsteer, and the suspension geometry is still good.
http://www.classicperform.com/Store/...6372CSSK-D.htm
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 08-02-2018, 11:44 AM   #10
RustyBucket
RustyBucket's Avatar
Re: Lowering
For ref. if you're gonna stay with the truck rally wheels. Mine's 2.5 drop spindles w/1 coil cut on the front and 4" springs w/ a 1" block on the rear. 255/60/15 front 275/60/15 rear. No rub, no bottoming on the rear. I did add an adj. track bar, short shocks(rear) and the shock relocator kit. Rides a little choppy I think.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 08-02-2018, 07:02 PM   #11
mkmc69
mkmc69's Avatar
Re: Lowering
I like the stance of your truck. What do you mean exactly by ''Choppy''? As in, maybe its a little on the stiff side, because of cutting the springs in the front? Just wanted a little more feedback, because I'm getting ready to go through all of this on my own truck.
mkmc69 is offline   Reply With Quote
Old 08-02-2018, 07:45 PM   #12
RustyBucket
Re: Lowering
Yeah, it rode softer before I cut the coils on the front. It had more spring travel before. It's not bad but my wife fusses if we're on a bumpy road or parking lot. I don't have a front sway bar but it goes around curves & corners with very little body lean.
Current toy trucks:
Old 08-02-2018, 08:24 PM   #13
mkmc69
mkmc69's Avatar
Re: Lowering
Thanks for the info. Maybe I will just do the spindles, and not cut the springs then. I still like the way yours looks though.
Old 08-08-2018, 11:08 AM   #14
68 P.O.S.
Re: Lowering
Every truck is different. Some folks don't need a c-notch with 6" lowering springs in the rear. Some do need a c-notch with only 4" springs. Luckily I didn't need a c-notch with my 6" springs and I haven't noticed any bottoming out either. I advise against cutting or heating springs as well, unless you like a crappy ride lol
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 08-08-2018, 12:31 PM   #15
azle
Re: Lowering
No notch 20" wheels, when it is aired down the Diff is sitting on the frame.
Azle
azle is offline   Reply With Quote
