Old 06-12-2019, 10:53 PM   #1
Driver_WT
Gap Between Running Board and Cab
I have a 53 3100 on an S10 chassis. The running board brackets are custom made by the previous owner. Can someone tell me what the gap between the top of the running board and the bottom of the cab should be (looks like it is about 1" currently).
Also, what how big should the gap be between the front of the running board and the bottom rear portion of the front fender?
Thanks.
Wade
53 Chevy 3100, SBC 350, 700R4, S10 frame
Driver_WT is offline   Reply With Quote
Old 06-13-2019, 12:29 AM   #2
mr48chev
mr48chev's Avatar
Re: Gap Between Running Board and Cab
If the gap is straight and even and the boards line up with the bottoms of the fenders right life is good.
Stand back about 30 ft and if everything looks right you are good (help from a rater critical buddy comes into pay here too) If it doesn't look right figure out how to correct it. The running board door sill, bottom of the door and top of the bed rails should all be on the same exact plane. = parallel lines. Nothing looks worse to me than this fad that seems to go with S-10 swaps that has the bed rail drooping down towards the rear in a misguided attempt to make the rear lower and ends up drooping like a diaper full of poo.
My ongoing truck projects:
Old 06-13-2019, 12:36 AM   #3
Driver_WT
Thank you MR48Chev. We definitely paid attention to getting top of bed rail, running boards and bottom of cab parallel. Plus we put some rake in the bed rails to match the line of the running boards. Running boards are lined up with the bottom of the front and rear fenders, so sounds like we are good to go.
Old 06-13-2019, 10:11 AM   #4
jweb
jweb's Avatar
I just measured mine and it's 7/8". I'm sure these vary from truck to truck. I think it's more important that they're parallel, plus there's a seal to help hide the gap.
https://www.classicparts.com/1947-54...ctinfo/56-011/
1951 Truck, LS1/4L60
1964 Suburban, next project
2018 Tahoe, daily driver
1953 Westerner "canned ham" trailer, restored
jweb is offline   Reply With Quote
Old 06-13-2019, 01:54 PM   #5
Driver_WT
Thank you. I am still learning about the many seals and gaskets on these trucks.
Old 06-14-2019, 12:52 AM   #6
mr48chev
mr48chev's Avatar
Cab to running board seals look like this https://www.classicparts.com/1947-54...ctinfo/56-011/
As Jweb said, they are to hid the gap but are one of those minor details that make for a better truck in the end.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
