Old 07-25-2017, 12:01 PM   #1
brown7373
brown7373's Avatar
Engine issue tap, tap, tap tap, tap, tap
Developed a continuous tap on my stock untouched 72 350. Using a mechanics stethoscope, I am 98% sure it is coming from number 2. I tried the magic potion (Risilone) hoping it was just a gummed up lifter, but no help.
I am pretty sure I have a bad lifter. It starts and runs fine at light load, but hates even moderate acceleration and increased rpm. Any thoughts about anything else it might be?
My plan is to replace the lifters and pushrods and hopefully nothing else unless I find something when I get into it. Will driving it gently do any other damage until I get time to take it apart?
brown7373 is offline   Reply With Quote
Old 07-25-2017, 12:20 PM   #2
harpo231
harpo231's Avatar
Re: Engine issue tap, tap, tap tap, tap, tap
Could be rocker arm worn
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 07-25-2017, 12:21 PM   #3
dirish
dirish's Avatar
I had a detonation issue. New crate tapped under load. It sounded like valve ticking. Vacuum advance adjustment helped. If you adjusted timing, or a new distributor it may be timing. Mine would not do it unless driving. Never at idol, even under throttle. Just a thought.
dirish is offline   Reply With Quote
Old 07-25-2017, 12:22 PM   #4
Jcfcamaro
Jcfcamaro's Avatar
Have you pulled the valve cover. Might be a loose rocker arm. But to figure that out you will need to turn the the engine over to top dead center and check half the valves as the Chilton manual then turn the engine over another full turn with the timing mark back at zero then run the other half of the valves.
Jcfcamaro is offline   Reply With Quote
Old 07-25-2017, 12:23 PM   #5
demian5
demian5's Avatar
Pull valve cover and ID the culprit.
I dodged a bullet by adding about half a pint of marvel mystery oil to the engine and poured right down onto the lifter.
I then started the engine every few days and let it get almost to operating temp.
Then one day it free'd itself, I adjusted the rocker and we live happily ever after.
the cause of my issue on my rebuilt low-mile 327 (that gets driven once every couple of months) was lack of oil changes (since the car sits). It was about 3 years since the last one. Ill have to do it for time and not miles from now on.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 07-25-2017, 12:25 PM   #6
demian5
demian5's Avatar
Oh and I've heard of guys snaking a single lifter out using magnets through the distributor hole...
1986 C20 Scottsdale
Instagram: C10sofOC
Old 07-25-2017, 01:44 PM   #7
brown7373
brown7373's Avatar
It taps at ALL engine speeds, but gets very bad under load and loses power. Obviously it speeds up as the rpms increase. Also, I don't want to push it because it sounds like it may really break something.
Old 07-25-2017, 01:56 PM   #8
D.PASSMORE
One of the First
D.PASSMORE's Avatar
You could be washing out your CAM. When you get the vave covers off. Look for glittering metal particles in the coners of the head. After it colls, dip your finger in that oil, the bigger the particle, the quicker its going out.
Im suggesting this, but it could be few other things.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 07-25-2017, 02:22 PM   #9
Big Block
Big Block
Big Block's Avatar
I had a rocker arm snap in half. The push rod was tapping the valve cover. It ran but not good. I parked it immediately and pulled the cover. Had t handles on the valve covers. Called a friend to pick me up and bring a socket set with him. Picked up a new rocker arm at the part store and replaced it where I parked it. Had it back on the road good as new. Good luck.
Big Block is offline   Reply With Quote
Old 07-25-2017, 02:51 PM   #10
hamjet
hamjet's Avatar
sounds like a broken valve spring or rocker.. maybe the tip of the push rod also.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 07-25-2017, 04:15 PM   #11
demian5
demian5's Avatar
I thought the worst case scenario...
(never considered detonation... even with the power pack heads)
Broken rocker
Pulled rocker stud
broken valve spring
flat cam
...untill I pulled my valve cover. Just a stuck lifter, but it sounded like the motor was broke.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 07-25-2017, 04:37 PM   #12
brown7373
brown7373's Avatar
My engine runs fine at idle and light driving, other than the sound of tap, tap, tap. At light throttle, 35-40 mph, windows up and A/C on, you wouldn't know anything is wrong.
I'll pull the rocker cover and check the springs & rocker arms. If they look OK and no evidence of metal filings, I will probably need to pull the intake and check the lifters.
Old 07-25-2017, 05:14 PM   #13
demian5
demian5's Avatar
Your issue will be obvious. Even with a collapsed lifter, one will be loose. Everything will not be OK. Look for metal like D.PASSMORE says.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 07-25-2017, 05:22 PM   #14
SuperChief
SuperChief's Avatar
I guess us amateures only get grief instead of encouragement to post
Last edited by SuperChief; 07-25-2017 at 09:00 PM. Reason: I guess us amatures only get grief instead of encouragement to post
SuperChief is offline   Reply With Quote
Old 07-25-2017, 05:37 PM   #15
jeffahart
jeffahart's Avatar
X2 on the exhaust leak.
White K20
jeffahart is offline   Reply With Quote
Old 07-25-2017, 06:15 PM   #16
demian5
demian5's Avatar
Originally Posted by SuperChief View Post
Sounds like an exhaust manifold leak Not kidding, worked for me.
Muffler bearing going out.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 07-25-2017, 07:25 PM   #17
Coley
Coley's Avatar
Smile Re: Engine issue tap, tap, tap tap, tap, tap
...lol....or maybe a torqued out bindel rotor.....
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 07-25-2017, 08:14 PM   #18
57taskforce
All about them K’s
57taskforce's Avatar
The fact that it looses power under load makes me rule out an exhaust leak. Like said above pull the valve covers and I bet the problem becomes relatively obvious.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 07-25-2017, 09:11 PM   #19
SuperChief
SuperChief's Avatar
Actually you may be correct and I missed the exhaust leak...."The canooter valve is a part of the exhaust regeneration assembly on new diesel engines. The canooter valve usually fails due to overheating of the exhaust bearings.
It's spelled "Canuter" not canooter. Over use of this valve is caused by faulty friggate switch wiring. When this happens, the muffler bearings become hot and can seize. Eventually, the catalytic converter fluid will become tainted with halogen bulb fluid due to canuter valve blow-by.
At this point, it's best to scrap the vehicle..."
Thanks for the astute observation. I did not intend tp hi-jack this thread. I will now only observe answers and refrain from comment.
Old 07-25-2017, 09:53 PM   #20
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
It was a joke... relax mang!
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 07-26-2017, 06:33 AM   #21
brown7373
brown7373's Avatar
I replaced the muffler bearings when I changed the muffler oil!
Old 07-26-2017, 09:13 AM   #22
67 chevelle
67 chevelle's Avatar
This is common nowadays , hope its not whats happening ,but is a possibility , especially if you are low on power .
Broken valve spring is also likely , much easier to fix , big blocks break them frequently , small blocks less often , remove your valve covers and hopefully the problem will jump out at you
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 07-26-2017, 10:21 AM   #23
Money_pit
Money_pit's Avatar
Are you using oil with the zinc stuff in it? Or just conventional oil?
These ole girls like the old oil not any of the new garbage.
71 C10 Finally took a leap and did the 5.3 4l80e swap.
Running the Holley Terminator Xmax. Still working bugs out.
Money_pit is offline   Reply With Quote
Old 07-27-2017, 03:46 PM   #24
brown7373
brown7373's Avatar
Zinc additive
Old 07-27-2017, 05:02 PM   #25
demian5
demian5's Avatar
Zinc additive
Did you pull the valve covers yet????
1986 C20 Scottsdale
Instagram: C10sofOC
