04-17-2016, 11:09 AM | #126 |
Re: 70 GMC 4wd version
Sounds awesome look forward to hearingfrom you.
04-17-2016, 02:54 PM | #127 | |
04-18-2016, 02:44 PM | #128 |
6>8 Plugless........
Your truck is looking great. I like your idea of the work truck paint job. Yours will sure looks better with time than the primer I put on my 95 Ford Crew cab.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
04-18-2016, 09:57 PM | #129 | |
Trailer got a winch [img width=750 height=562]http://i114.photobucket.com/albums/n277/70gmc/A1CC8B38-9160-4D6B-8F14-EE50160EBC2B_zpsrt3tf5n3.jpg[/img] [img width=750 height=562]http://i114.photobucket.com/albums/n277/70gmc/57880446-93EF-46C5-AB5C-779255B5A304_zpsl960nkob.jpg[/img] [img width=750 height=562]http://i114.photobucket.com/albums/n277/70gmc/D7AB1883-6359-42A7-8CD9-022ED1F28FFB_zpsoigx82qn.jpg[/img] [img width=750 height=562]http://i114.photobucket.com/albums/n277/70gmc/Trailer/F1E77910-38B5-4BE6-B624-29062B4B920F_zpsu9mz0gqv.jpg[/img] |
04-18-2016, 10:00 PM | #130 |
10-15-2016, 09:54 PM | #131 |
anything new done to the truck?
10-16-2016, 11:00 PM | #132 |
ya I took a few months off from it, then I put on a fitech fuel injection kit on it and drove it for about 3 months. Never really was to happy with it, so I sold the fuel injection to a buddy of mine and sold the big block and the 700r4 about 2 weeks ago.
10-22-2016, 05:15 PM | #133 |
Today I got the donor truck stripped down and ready to pull the motor and the transmission tomorrow, Also go the dirty dingo motor mounts installed. They are great quality and I would recommended them to anyone, however I was a little disappointed that I had to modify my relatively new ss brakes lines because the mounts don't have a provision to allow them to pass thru.
heres the donor truck I bought for 900.00 bucks Dirty dingo mounts |
10-22-2016, 05:55 PM | #134 |
weird looking mount/cross member
Is that a LS 5.3 liter motor? What did you do with the orange paint job, sand it off. or what? ? ?
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4, Pinstriping-Lettering-Specialty Painting Last edited by GSP7; 10-22-2016 at 06:10 PM. |
10-22-2016, 06:11 PM | #135 |
yes it is a 5.3 ls. I am going to be running the 5.3 with 4l60e out of the donor truck also along with my 208 transfer case, just have to figure out how to make the vss work as it is the transfer case out of the donor truck.
The mount/crossmember is a dirty dingo unit, I went with it because I really liked how the bottom part is removable incase a oil pan is ever needed to be removed while the engine is in the vehicle. |
10-22-2016, 10:10 PM | #136 |
following the ls swap
I have a longhorn chassis that's getting converted to 4x4 this winter and was looking at the dirty dingo crossmember as its getting a 6.0/4l80 I used the mounts the dirty dingo mounts in our suburban that got 6.0/4l80. There mounts fit perfectly. LS swap is best thing I ever did to that truck.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
10-24-2016, 09:14 PM | #137 | |
10-26-2016, 08:28 PM | #138 |
No my 208 is out of a 85 k5 blazer so it is a passenger side drop. I just need to figure out how to make it read a vss. From what little research I have done I believe I can take the 241? Apart out of the donor truck and rob the vss and the reluctor out of it and the just drill and tap my tail shaft on my 208.
01-22-2017, 08:53 PM | #139 |
01-23-2017, 01:04 AM | #140 |
That's a start, good for you.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
01-30-2017, 07:42 PM | #141 |
09-14-2017, 09:40 PM | #142 |
got the 5.3 running fighting vss and trans not shifting kinda at my wits end now.
thinking im gonna do a adavance adapters part number 50-0405e, anyone have any experience? on a side note what photo site are people using now that photobucket did their change???? |
02-18-2021, 06:07 PM | #143 |
Trying to get pics to work, any advice on getting them to rotate?
02-18-2021, 10:27 PM | #144 |
ive found if they turn out sideways..i rotate them to correct...usually they will be right..if not then i then crop the sides off and they will usually stay right side up
02-19-2021, 10:24 AM | #145 |
lets try this
02-19-2021, 10:24 AM | #146 |
Hey man that worked great, Thank you!
02-19-2021, 11:00 AM | #147 |
All about them K’s
Looking awesome!
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
02-19-2021, 06:16 PM | #148 |
02-20-2021, 06:29 AM | #149 |
Nice truck. Reminds me of my youth and first 72. Growing up in in the snow. Good work on the mods.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
02-20-2021, 12:08 PM | #150 |
All about them K’s
Is that still 4” and 35 12.5s?
