09-03-2017, 05:14 PM | #1 |
Lower shift linkage for 402/400TH
These came off a 71. My 72 has the same. By chance anyone know where to get more of the retainer washers for the shift lever spring? The hole in these retainers are oblong. Classic Industries sells a replacement shift lever with one of these retainers, or similar. The original used two.
Haven't put things together, but I believe the bushing replacement per this image should work. Thank you. Edit: Just threw one of those bushings on my 72, works fine. The shaft is a pinch longer than original, so I shaved it off. Didn't do anything to the flange side. If anything, seems to be a better fit.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 09-03-2017 at 06:20 PM. |
09-03-2017, 05:18 PM | #2 |
Moderator
Re: Lower shift linkage for 402/400TH
Take the sample to Lowes or Home Depot hardware section...
they are either 5/16 or 3/8 plain steel washers... |
09-03-2017, 06:41 PM | #3 |
Thanks, I'll do that. I just realized I was looking for a washer with a rectangular hole. Helps to enter a proper description, They're oblong and come right up.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
09-03-2017, 07:54 PM | #4 |
OC truck shop lists those parts...not sure how well they fit
09-03-2017, 08:11 PM | #5 |
Moderator
They dont need the rectangular holes...round ones will work fine...
I havent used the rectangular ones for years.... |
