Old 02-21-2019, 12:09 AM   #1
69GMC2004
Active Member
C10 suspension upgrades
I'm doing a total upgrade to my 69 C20, will basically just be using the frame and body if truth be told. All of the suspension components will be replaced with C10 components (all new), so my question is, would it be worth it to upgrade to the 71-72 components (ball joints, etc) or stick with 69? Cost will be virtually the same.
What's your thoughts?
69GMC2004 is offline   Reply With Quote
Old 02-21-2019, 08:53 AM   #2
Mike C
Mike C's Avatar
Re: C10 suspension upgrades
If you are not switching to disc brakes that is a huge mistake IMO. And if you do, you Will need to use different ball joints and tie rod ends that are appropriate for your vehicle.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-21-2019, 09:25 AM   #3
68Gold/white
If you are going disc brake, you will have to use the 71-72 ball joints.
Do NOT convert your pickup using front drum brakes!!!
68Gold/white is offline   Reply With Quote
Old 02-21-2019, 09:33 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Not true.
MANY companies make standard or drop spindles to work with your cuurent ball joint and tie rod ends.
Making it easy to add disc brakes to your truck.
The years for conversion spindles are:
60-62 and 63-70
You can also use 73-87 parts if you want to convert to rubber bushed a-arms.
Keith
Convert to disc brakes.
Old 02-21-2019, 09:35 AM   #5
69GMC2004
Active Member
The truck is going to get a front and rear big brake kit, don’t worry lol. But all of these aftermarket parts I’m looking at are available with the 69 style ball joints or the 71-72.
Old 02-21-2019, 09:36 AM   #6
lolife99
lolife99's Avatar
You can add C10 upper balljoints to your current upper a-arms.
The C20 lower a-arms have a larger balljoint hole in them.
So you will need to use C10 lower a-arms with whatever balljoint matches the year of spindle you decide to use.
Keith
Old 02-21-2019, 08:10 PM   #7
69GMC2004
Active Member
I guess maybe I can make this a little bit more simple, is there any noticeable advantage to using 71-72 c10 ball joints vs using 69 c10 ball joints?
Old 02-21-2019, 09:45 PM   #8
lolife99
lolife99's Avatar
No.
Just make sure the spindles you buy, match the balljoints and outer tie rods.
Keith
Old 02-21-2019, 10:11 PM   #9
Mike C
Mike C's Avatar
Arguably, the 71 and up components were improvements over the 70 and early which is why GM switched to them.
My 69 only had 66,000 miles on it when I did the disc conversion and the balljoints were like new. So I just die the conversion spindles.
But if I was replacing everything, I would use all stock for the disc brake parts.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 02-22-2019, 04:36 AM   #10
simenad
I would go for 73-87 parts as they use the heavier duty ball joints. And tie rod ends which are more common and more accessable.
simenad is offline   Reply With Quote
Old 02-22-2019, 12:52 PM   #11
68 P.O.S.
I would look at ECE's website. They've got the disc brake conversion kits, suspension kits, and the front end rebuild kits. I put all 3 on my truck and they work perfectly. I also added front and rear sway bars. What a difference brand new suspension and sway bars made
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
