04-10-2018, 12:29 PM | #1 |
18" Wheels: Tire sizes
I've had a set of 18x8/9.5 Ridlers for a few years with 235/55-18 on the front and 255/55-18s on the rear. The fronts at about shot and I've currently got them on my '72 driver. I'm planning on putting a set of 20s on it later this year and the 18s back on my '67 project to roll around the garage in.
I'm finding there is not a whole lot of 18" tires in the 27-29" tall range which I'd like to have since I have a 4.11 rear end. The 255/55s are about 29" tall. A guy at one of the local tire shops has a set of Michelins in 235/60 and 265/60 I can get real reasonable that could get me by until the budget allows for new tires/wheel. The fronts would be about 29.5" tall and rears 30.5" tall. Anybody running either one of these tires? I'm curious if they would be too tall and look kind of goofy. Truck is getting lower about 4" in the front and 5" in the rear here real soon. Current setup: Anybody want to post up pics of your 18s and tire sizes?
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
04-10-2018, 12:49 PM | #2 |
Re: 18" Wheels: Tire sizes
this does not make since to me , you are going to run a 60 series tire all the way around and that means that the sidewall height should be same , just a wider tire in the back
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
04-10-2018, 12:53 PM | #3 |
I am running 265/50/18 all around on 18x9's. You are right that there are not a lot of tires in this range. I am possible thinking of going to a slightly shorter tire in the future. Maybe a 45 series tire.
04-10-2018, 01:06 PM | #4 |
The 60 is 60% percent of the width of the tire so a 265/60 would be taller than a 245/60.
04-10-2018, 02:07 PM | #5 |
Truck looks good. If I go shorter I probably need to change the rear gear.
04-10-2018, 02:52 PM | #6 |
I bought a set of off brand (CHEAP) 255/55r/18's for the Blazer. 18"x 9" Torque Thrust all the way around. It sits almost level and they fill up the openings pretty well. No rub. So far I'm pleased with them. They're "V" rated and seem to be pretty sticky... wrung my driveshaft off first time I dumped the clutch.
Dad always said, "Son, WISH IN ONE HAND, and ......." -------------------------------------- -------------------------------------- Current toy trucks: '71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C '72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these: '66 Plymouth Belvedere City of Miami cop car clone. '70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!! '67 C10 short/step side mount spare -- SOLD!! '72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!! '69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!! |
04-10-2018, 05:20 PM | #7 |
255/45/18 front and 295/45/18 in rear is a good combo.
04-10-2018, 05:39 PM | #8 |
255/55/18 front 275/60/18 rear Ridler 18X8 front 18x9.5 rear 2.5/4 drop
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
04-10-2018, 06:28 PM | #9 |
Here's a link to a tire size site. Lots of good info here
https://tiresize.com/calculator/
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
04-10-2018, 06:51 PM | #10 |
I agree but those rear tires are too expensive to put on a cheap set of Ridlers
04-10-2018, 06:53 PM | #11 | ||
04-12-2018, 12:01 PM | #12 |
There you go reminded something new everyday, i had forgotten that
04-12-2018, 03:17 PM | #13 |
Here is mine
Fronts are 255/55-18 Rears are 285/50-18 9.5 inch wheels
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
04-12-2018, 03:19 PM | #14 |
I bought these a few years back and had a real hard time finding sizes I liked. These are Toyo Proxy ST2 if I remember correct.
04-13-2018, 07:12 AM | #15 |
I bought Master Craft tires, 285-60R-18 for the rear and 265-60R-18 for the front. I only lowered the rear 2" and the front 2 1/2 in the front. This picture is after I removed engine and transmission for paint and rebuild. I did not see any rubbing issues with the front or rear. The wheels are Ridler 18X8 front and rear.
