02-16-2019, 11:06 PM | #451 |
Happy to be here
Re: "Crewcab Jake" the 84 to 74 conversion
While Aaron's doing his thing on the cab Chris and I are moving forward with the bed. We decided it would be easier to install the wheel well molding with it upside down. As expected, we had to drill new holes and adjust the shape as we progressed.
02-16-2019, 11:14 PM | #452 |
Happy to be here
With the molding installed Chris and I turned our attention to the taillight buckets. I decided I wanted to protect the exposed area with undercoating. We prepped the surface and masked the exterior area.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-18-2019 at 01:05 PM. |
02-16-2019, 11:17 PM | #453 |
Happy to be here
We sprayed undercoating inside the opening. We were able to cover quit a bit of area that's typical left unprotected.
02-16-2019, 11:27 PM | #454 |
Happy to be here
While Chris gathered parts and the corresponding bolts for what we plan to install tomorrow I worked on small parts.
The new grill needs a a cubic inch emblem and I dont have a nice one. I pulled the one from my mock up grill and set out to restore it. The original paint was badly faded and pitted. I stripped its clean then masked it off.
02-16-2019, 11:28 PM | #455 |
Happy to be here
With the masking done I layed down several light coats of satin black
02-16-2019, 11:56 PM | #456 |
Happy to be here
Unfortunately I had a big setback after removing the masking. The syringe I had loaded with red paint to fill the numbers stuck then let go and I blasted red paint everywhere.
After a complete meltdown I stripped all the paint off again and started over. I decided I couldn't end the evening defeated so I moved on to the next project.
02-17-2019, 12:02 AM | #457 |
Happy to be here
We had pulled a Silverado tailgate band from my stash in the attic. It was in mint used condition but needed a good cleaning.
I pulled the Chevrolet emblem off and cleaned then polished the surface. It's not perfect but it's darn close.
02-17-2019, 12:07 AM | #458 |
Happy to be here
While I had the emblem of I cleaned it thoroughly with glass cleaner and a toothbrush. The chrome polished up nicely but the black on the letters was a bit thin. I painted them with satin black and installed it back on the band
02-17-2019, 07:52 AM | #459 |
Is undercoating under the taillight housing going to affect the grounding of the taillight?
Rick |
02-17-2019, 09:11 AM | #460 |
I don’t know the answer, but weird stuff like that can happen with grounds. When I replaced the wood on my stepside bed I started having problems with the taillights. I was getting real frustrated with it. Finally, I added a ground strap from bed to frame and they’ve worked fine ever since then. I guess the new wood somehow interfered with the ground. So I guess even undercoating on the bottom of the bed floor could possible effect the ground.
02-17-2019, 01:48 PM | #461 |
Very nice work! Hardly can´t wait to see what it looks like ready. I've been dreaming about crewcab for a long time.
Ilkka 1984 Silverado 6,2d http://67-72chevytrucks.com/vboard/s...d.php?t=731803 BMW 325i 1989 http://67-72chevytrucks.com/vboard/s...d.php?t=797823 |
02-17-2019, 07:15 PM | #462 |
Movin' along quick. Looks good.
02-17-2019, 09:59 PM | #463 |
Happy to be here
We anticipated that and masked over the spot where the ground goes.I will sand the area and use a star washer to ensure continuity.
02-17-2019, 10:03 PM | #464 | |
Happy to be here
02-17-2019, 10:15 PM | #465 |
Happy to be here
Today Chris and I loaded up our supplies and headed over to Homegrown Hotrods. Aaron and his crew and been working on parts prep all week and it was time to start assembling the results of their effort.
They had prepped and painted the rear inside of the cab as well as the dash.
02-17-2019, 10:25 PM | #466 |
Happy to be here
Aaron and I worked on hanging doors while Chris worked inside the cab. I recently closed a deal with Vibro Solutions to provide the sound deadner and thermal barrier system for Jake.
We wont have time to do the entire cab but we did want to do a panel to test it out. We were very pleased with the ease of installation due to the flexibility added by the grid pattern. The design provides elasticity to the material and assists with alignment.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-18-2019 at 01:08 PM. |
02-17-2019, 10:30 PM | #467 |
Happy to be here
Aaron and I got the doors hung and he did an initial alignment. Typical of GM doors, they will require lots of tweaking to get them fitting properly.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-18-2019 at 01:09 PM. |
02-17-2019, 10:38 PM | #468 |
Happy to be here
Once all the doors were hung we worked on the fenders. One went on fairly easy and the other required a lot of adjustments.
After Lonestar Throwdown the panels will come off for proper adjustments before final prep and paint. Until then the minor discrepancies in fitment will have to suffice.
02-18-2019, 10:58 AM | #469 |
I'm just glad to be here!
Jake is shaping up nicely. I hate that we are going to miss LST this year, to many personnel issues this past year...
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
02-18-2019, 01:09 PM | #470 |
Happy to be here
Thanks Karl. Sorry to hear you cant come. I looked forward to chatting with you.
02-18-2019, 10:16 PM | #471 |
Happy to be here
Aaron decided to keep Jake another day and block him down again. Meanwhile I'm chasing down small parts. I had lost track of the new rain gutters I had picked up so I tracked them down. The stainless was in excellent condition but the painted part was faded.
I scuffed them down and masked off the stainless. I hit them with primer and let them cure while I made a parts run. When I got home I added the satin black. After a couple of coats the were left to dry.
02-18-2019, 10:27 PM | #472 |
Happy to be here
While out picking up parts for my tailgate I got a text from Aaron at Homegrown Hotrods. He and his crew put in a long day blocking and prepping the Tamco Paint They cut the Tamco HP 5311 High Build 2K to start the process then followed it with a coat of Tamco HP6003 to seal it up for now.
If you have never tried Tamco Paint you need to check it out. They are a small independently owned company that caters to the custom car culture. They offer premium quality paint products at a significantly lower cost. Jake has a lot of flat panels to get straight but Aaron and his crew were up for the job. This will be how it rolls for Lonestar Throwdown.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-19-2019 at 10:57 AM. |
02-19-2019, 12:11 PM | #473 |
Happy to be here
Heres a sneak peek of the new #vf527 from @americanracing built for #crewcab #jake
Full view coming soon
02-19-2019, 03:06 PM | #474 |
It is refreshing to see that you have multiple pictures with rattle can paint in this thread. At your level of building and the stage your trucks get photographed and shown, it makes me feel better about how my truck is built. Looks sick so far, can't wait to see the wheels.
Frank (Hilo, Hawaii) Trucks, Tacos, and Beer go together like Peanut Butter and Ladies! 85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383 67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298 79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461 |
02-19-2019, 10:37 PM | #475 |
Those wheels have a Venture Drag Mag mag of the '60s look.
