Old 03-30-2017, 06:49 PM   #126
CTENTA1
Registered 1971 K5
Re: Blazer half cabs
Originally Posted by Chulisohombre View Post
They chopped out the back window for the rollbar. Kinda kills it as it would need a lot more work to make it a half top again instead of just a sun roof.
I think they used a full top and cut that front portion (home made) like mentioned above.
CTENTA1 is offline   Reply With Quote
Old 03-30-2017, 10:26 PM   #127
Pjay3000
Hey guys I am new to this I just buy my 71 blazer and I am looking for a half cab
Pjay3000 is offline   Reply With Quote
Old 03-30-2017, 11:50 PM   #128
Pjay3000
480-695-6728 PJ give me a shout when you get done making one of those would definitely love to get one off you
Old 03-31-2017, 02:36 PM   #129
Chulisohombre
Chulisohombre's Avatar
To me it looks like it was a half top to begin with. If they cut down the original top, It would be a flat cut at the back and not have the double drip rail like it has. Either way I have had a double wall homemade one and what they did was cut down a double wall and then put the hatch in place as the back window with bondo and sheet metal. It wasn't too bad looking but I went a different direction with mine and needed space so I sold it.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
Old 03-31-2017, 02:43 PM   #130
Pjay3000
Cool I finally got one of the guys on here to email me back on the original fiberglass ones we'll see how that goes my buddy has one and it came out pretty clean
Old 04-17-2017, 05:20 PM   #131
raggedjim
raggedjim's Avatar
In this thread a guy built one from a full top for his pickup truck that looks really good...
http://67-72chevytrucks.com/vboard/s...d.php?t=577069
Roger
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 10-09-2017, 07:16 PM   #132
truckeez
The New version of the 76-91
truckeez is offline   Reply With Quote
Old 10-09-2017, 07:27 PM   #133
Pjay3000
Hey if you could give me a call sometime 480-695-6728 I want to see what's on volved I'm getting at half cab thanks
Old 10-09-2017, 07:46 PM   #134
truckeez
Well this 76-91 version is pretty much the same as, you get a sheetmetal shop to fab the lower bedwall, get 4 buddies to come over and remove the heavy factory one, and simply bolt in the custom stuff,
(you mask off the floor and wax it and set the bedwall in place temporarily set upward slightly lile 1/32 " pump in scilicone to form the lower bedwall gasket~ clean away excess Tidy-ly)
and once its set up yo then bolt the bewall in place, it seals -But is not stuck to the floor.
Old 10-09-2017, 07:58 PM   #135
truckeez
and once its set up yo then bolt the bewall in place, it seals and is not stuck to the floor.
This rear walls lower edge turns back on a 76-91 style, on the 69-72 if goes forward
Old 02-28-2018, 01:35 PM   #136
Zsanders
Hey everybody, new to the group. I have a Pacesetter half cab and Iím looking for a bulkhead or a diagram so I can build one. Iíll try and add a pic of my 71 2wd with the half cab on it.
Zac
Zsanders is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
