Old 04-17-2017, 12:41 PM   #1
6768chevylover
6768chevylover's Avatar
soft blazer suspension
I'm looking for how to soften a ride on a 71" blazer 4x4 with out adding any lift to it? willing to fabricate...
6768chevylover is offline   Reply With Quote
Old 04-17-2017, 01:17 PM   #2
cleszkie
cleszkie's Avatar
Re: soft blazer suspension
4-link front and rear with coil over shocks. Seriously though, I've had great results with my Superlift "Softride" front and rear leaf springs combined with Bilstein 5100 series gas charged shocks. I run 2" lift springs, but I think they may offer stock height springs as well. You may also look into ordering a set of Alcan or Deaver springs, which use spring packs consisting of a higher number of thin leaves to achieve load capacity with a soft ride. I typically don't recommend removing leaves from stiff spring packs to soften them up, but you could try that as well if you have some thick overload springs.
cleszkie is offline   Reply With Quote
Old 04-17-2017, 04:26 PM   #3
praisegeetarman
I am very please with the ride on my 71. I installed add a leafs. It did raise the height 2", but the ride is much better than stock. Also, it's fairly inexpensive.
Keith
71 Blazer 4X4 (unmolested, all original (including paint) 74,000 mile barn find)
67 Camaro RS SS (unmolested, all original (including paint) 81,000 mile barn find)
Keith Riel
praisegeetarman is offline   Reply With Quote
Old 04-17-2017, 04:50 PM   #4
JohnJ@RideTech
JohnJ@RideTech's Avatar
Just changing out the shocks to something with a little rebound control would help you out a lot. Being able to make those adjustments allows you to fine tune the ride quality to fit YOUR needs instead of just pulling something out of the box and hoping its soft enough for you. Its also probably one of the most cost effective ways to enhance your ride quality as well.
On a side note, there are a few other variables that can affect overall ride quality. Everything from the types of tires and tire pressure that you run to the seats you plant your butt on.
If you have any further questions about shocks, be sure and let me know. Ill be more than happy to help you out if I can.
John J.
Sales/Tech
Direct Line: 812-481-4737
Office: 812-482-2932
JJohnson@ridetech.com
Instagram: @ridetech_john
JohnJ@RideTech is offline   Reply With Quote
Old 04-18-2017, 01:04 AM   #5
87Skier
87Skier's Avatar
What kind of shocks do you recommend? Any that you've had luck with?
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 04-18-2017, 07:58 AM   #6
JohnJ@RideTech
Sorry I missed your call yesterday. Chase said he talked to you for a bit. Give a shout if you have any other questions or feel free to shoot me a DM on here if you would like.
John J.
Sales/Tech
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
