Old 04-17-2017, 02:41 PM   #1
71PICKEMUP
71PICKEMUP's Avatar
63-66 V8 fan shroud
I recently stumbled onto a '65 or '66 Suburban while scrounging for parts.
It is a factory V8 truck. It still has the original plastic radiator fan shroud, and it is in great shape.
I was thinking about trying to work the shroud into the deal with the other parts.
I don't recall ever seeing one. How rare is it?
71PICKEMUP is offline   Reply With Quote
Old 04-17-2017, 05:16 PM   #2
duallyjams
PICS IM MY PROFILE
duallyjams's Avatar
Re: 63-66 V8 fan shroud
They make repro fan shroud for 64-66 chevy trucks. The originals are usually crack, split or broken.
James
2002 GMC cc dwr sporting alcoa D-max 22MPG
63 GMC V6 4speed carryall
64 GMC lwb 3/4 V6 4speed seeking factory optionSOLD
65 chevy swb bbw V8 auto
66 GMC swb bbw buddy bucketsSOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 04-17-2017, 08:24 PM   #3
La Zona Imagery
what does the fan shroud do i dont have one in my 65
1965 Chevy C-10 350 V8
2003 GMC Sierra Crew Cab 6.0L 4x4
La Zona Imagery is offline   Reply With Quote
Old 04-17-2017, 10:24 PM   #4
DPowers
One foot in front of the other
DPowers's Avatar
The OEM ones usually got thrown away when the radiator or water pump got changed. The shroud helps with the efficiency of cooling of the engine.
DPowers is offline   Reply With Quote
Old 04-17-2017, 10:41 PM   #5
andyh1956
Did the OEM shroud fasten to the radiator or to the support?
Is the shroud adaptable to aftermarket radiators?
I have an OEM shroud from a '63 Impala I was gonna try to use on mine.
andyh1956 is offline   Reply With Quote
Old 04-17-2017, 10:47 PM   #6
'63GENIII
'63GENIII's Avatar
Exclamation Re: 63-66 V8 fan shroud
It attached to the sheetmetal extensions on the either side of the radiator. I have repoped shroud for a 64 on mine. With a 21" fan, I had to do a little trimming but it does work well.
Is your '63 Impala shroud the one that looks like metal corrugated pipe section?
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 04-17-2017, 10:54 PM   #7
DPowers
DPowers's Avatar
OEM V8 radiator shrouds attached to two panels that bolted to the core support.
Old 04-18-2017, 06:32 AM   #8
duallyjams
PICS IM MY PROFILE
duallyjams's Avatar
The fan shroud helps in the summer months if you get stuck in traffic or maybe a parade.
James
IG duallyjams
Old 04-18-2017, 06:47 PM   #9
AcampoDave
AcampoDave's Avatar
Aside from helping the fan out at low speed, it does provide a certain element of protection too. You know...from stuff like falling beers or getting the drawstring to one's hoodie wrapped up in the moving blades while bending over the radiator. (Ouch, that'll leave a mark)
AcampoDave is offline   Reply With Quote
Old 04-18-2017, 07:20 PM   #10
'63GENIII
'63GENIII's Avatar
^^^^ Agreed. The deluxe models had a built in 16 oz insulated cup holder.
Chris
'63 k15 long step
Old 04-20-2017, 02:08 PM   #11
andyh1956
Yes that's the one. It would fasten to the rad support unless I modify it.
Copyright ©2000 - 2018, vBulletin Solutions Inc.
