Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-10-2017, 08:19 PM   #1
dsquad13
Electrical drain
1969 chevy c20. 350 4 speed. So every time I turn the key on my truck the starter clicks a couple times and gets stuck, and then mY battery voltage plummets. Prior to turning the key the battery holds a steady 12.5-13 volts. This problem sprang up out of nowhere. I had my alt and starter tested and both checked out fine. Battery was new in October. Any ideas what could be causing such a huge drain, and also why the starter keeps sticking?
dsquad13 is offline   Reply With Quote
Old 04-11-2017, 01:14 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Electrical drain
How old is the starter? If you had it tested off the truck it may have tested fine, but on the truck with a load on the armature with worn bushings, it's possible that the armature might drag against the field poles and turn slower.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-11-2017, 10:23 AM   #3
Dead Parrot
Possible the battery has died. There is a reason they come with warranties.
Does the voltage go to near zero if with the engine off, you turn on the brights, blower motor to max and turn on the wipers?
Double check the battery cables. They can look good and be rotted on the inside. Clean the clamps and battery terminals. A little corrosion can cause a connection to go bad when a lot of current tries to go through.
Dead Parrot is offline   Reply With Quote
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
