Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 04-19-2017, 09:07 AM   #1
Nate781
1970 C10 No Brake Lights or Tail Lights
Ive been working on a friends 70 short bed. I replaced all of the wiring harness's on the truck. He did not have tail lights, brake lights and back up lights. I noticed a majority of his wiring had been cut or shorted out. So I replaced all of the harnesses, light switch, dimmer switch except the engine harness and turn signal switch. Still have issues. I replaced the brake switch under dash thats by the brake pedal. I got the the lights working last month when I unplugged the bulkhead harness and re tightened the bulkhead. Now no lights again. Ive made sure all grounds are grounded correctly and added a couple more. NOT sure whats going on. Im thinking its in the turn signal Any help or suggestions would be great.
Nate781 is offline   Reply With Quote
Old 04-19-2017, 01:17 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: 1970 C10 No Brake Lights or Tail Lights
First of all check for power on the rear lights at the harness connector just ahead of the rear lights. This will indicate whether the wiring to the rear is good or if the problem is ahead of the harness in the cab.
The wiring for the rear lights goes through the connector plug in the firewall behind the distributor. The turn and brake lights come directly from the turn signal switch on the steering column. If the turn signals work, then the wiring for those is good and the brake lights use the same wires, so the harness is good, and the problem is in the turn signal switch or the connector.
To check the brakes, locate the white wire on the steering column connector and check it for 12 volts when you press the brake pedal. If you get 12 volts then check the yellow and dark green wires for 12 volts when you press the brake pedal.
If you get 12 volts then the TS switch is ok and the problem is in the harness wiring. It is possible for the turn signals to work, but the brakes lights may not if the connections are no good in the TS switch.
The tail lights work from a separate wire from the headlight switch. It's a brown wire, and it runs from the headlight switch to the inside of the connector, where the rest of the rear lights plug in behind the distributor.
The reverse lights' wiring runs from the fuse panel to the neutral start switch on the column (automatics) to the rear lights, through the same connector with the other wires. Check for power at the light green wires on the NSS, with the key on one of those will have power. If you jump them together and the BU lights come on then the NSS is bad or it isn't working with the column shifter. If not then the problem is in the harnes or the rear lights.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 12-15-2017, 01:13 PM   #3
Nate781
VetteVet, have another question for you. I took care of the 70 c10 now Im having same issues with a 69 im restoring. No rear tailights or brake lights. I was wanting to know, if I should have 12volts at the brake switch? I have power to neutral saftey switch but nothing to the orange/white wires to the brake switch. Rear lights work only when using the turn signals. Also, dome lights and cluster lights arent working. Im assuming thats a separate issue. All of the wiring is new expect for under dash. Under dash harness is in really good shape, no broken wires in bulk head.
Old 12-15-2017, 07:42 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
The orange wire to the brake light switch and the dome light are powered from the battery and not the key switch. There is a 12 gauge red wire tee in the harness under the dash and it sis shown in the following diagram. The wires are 12 gauge and they feed the horn relay, the light switch, the ignition switch, and the fuse panel. The one to the fuse panel supplies the full time 12 volts to the orange wire for the stop switch the dome fuse and the stop tail fuse.
The orange wire that supplies the stop switch,dome fuse, and stop tail fuse also supplies the power to the headlight switch for the tail lights and the dash lights.
This is a clue that your problem is in the fuse panel since all those aren't working.
This diagram shows the key switch and the headlight switch where the red wires come in to the key switch and the orange wires go to the headlight switch and are extended from the fuse panel to the dome light.
Name:  Copy of Cab-2-web.jpg
If you have no power at the brake light switch then the fuse for the stop tail lights could be bad.
VetteVet
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
