Old 06-27-2018, 01:21 PM   #1
philB
Question TH400 info
have a TH400 in my 67 c10 2wd w/350, want to add a trans temp and pressure gauge and not sure where to look for proper access to add a fitting. Is the cooler line ok or somewhere else on trans case.
philB is offline   Reply With Quote
Old 06-27-2018, 11:26 PM   #2
Captainfab
60-66 Nut
Re: TH400 info
In the past, I've welded a bung in the pan for a temp gauge. You just have to be sure there is no interference issues.
Old 06-27-2018, 11:39 PM   #3
philB
Thumbs up Re: TH400 info
thanks for the reply, i was thinking about putting a tee fitting in the cooler line to the radiator, the temp sensor is a 3/8" thread and not too long, try different
fittings to keep the sensor not too much in the flow, not sure if this will be OK
for good temp readings.
Old 06-28-2018, 07:20 AM   #4
cadillac_al
Re: TH400 info
My B&M trans temp gauge came with the fitting for the cooling line. It was very simple.
76 Chevy K20
76 GMC K15
77 Chevy C10
cadillac_al is offline   Reply With Quote
Old 06-28-2018, 08:27 AM   #5
philB
thanks for the info, i'll look it up, next on the list is a good transmission rebuilder
Old 06-28-2018, 11:06 PM   #6
Captainfab
60-66 Nut
Re: TH400 info
If you put the sender in the cooling line, make sure it is in the line coming from the trans and not going back to the trans.
Old 06-29-2018, 12:02 AM   #7
philB
will do, thanks , think the top line is out, waiting for parts to get here from mail order
Jegs, using their led gauges etc.
Copyright ©2000 - 2018, vBulletin Solutions Inc.
