Old 06-18-2018, 02:26 PM   #1
Erix
posi rear end gears
My 87 Silverado is finished except for the posi rear end. I have the 350 engine with the 4 speed (overdrive) transmission that came in it. The right rear tire will light up but the drivers side doesn't. Some tech lines say 373 is best all round.I'm not racing it. Just a cruiser but would like both tires to spin and get reasonable mileage. What are other 350 guys installing that fits the bill.
Thanks,
Eric
my project can be viewed at :
https://www.fuelcurve.com/1987-chevy-c10-pickup/
Erix is offline   Reply With Quote
Old 06-18-2018, 02:47 PM   #2
YoungPup1977
YoungPup1977's Avatar
Re: posi rear end gears
If you have a true posi differential than I would think both tires should lay down the rubber....if you dont, you can add the posi carrier without replacing the gears...Good luck on smokin both tires !!!!!
YoungPup1977 is offline   Reply With Quote
Old 06-18-2018, 11:38 PM   #3
Captainfab
60-66 Nut
Beautiful truck!
What gears will partly depend on what the diameter is of your rear tires and what you want out of a gear change. Are you looking for better performance or lower RPM's at highway speeds? Lower rpm's don't always mean better MPG's. The engine needs to run in it's 'sweet spot' for best efficiency.
Old 06-19-2018, 02:11 PM   #4
Erix
I have 20Ē Mickey Thompson tires ! All I want to do is spin both tires. I can live with current gears. Thanks !!!
Old 06-19-2018, 11:33 PM   #5
Captainfab
60-66 Nut
20" diameter tires..........what are those on 13" wheels?
Originally Posted by Erix View Post
I have 20” Mickey Thompson tires ! All I want to do is spin both tires. I can live with current gears. Thanks !!!
If you want a posi, then you will have to either install one or have it installed.
Old 06-20-2018, 03:06 AM   #6
Erix
Sorry !!! My wheels are 20ís on rear and 18ís on front!
Old 06-20-2018, 03:11 AM   #7
toolboxchev
Get a Detroit True Track...Eaton brand.
toolboxchev is offline   Reply With Quote
Old 06-20-2018, 03:46 AM   #8
Erix
Thank you very much !!
Old 06-20-2018, 11:40 PM   #9
Captainfab
60-66 Nut
The OUTSIDE diameter of the rear tires is what is needed to determine the optimum gear ratio for the desired usage, not the wheel diameter. Your original post sounded like you were wanting a gear change also.
Sorry !!! My wheels are 20’s on rear and 18’s on front!
Old 06-21-2018, 03:26 AM   #10
Erix
Iím open to change gear size if it would help but if I can posi what I have, thatís fine too. Iím trying to determine whats the best approach at this point.
Thank you for helping !
Old 06-21-2018, 09:58 AM   #11
b454rat
I’d say 3.73s maybe 4.10s. With either gear the drivetrain won’t be working as hard, so tho seems backwards but would get better mileage, while having fun at the same time lol...
Old 06-21-2018, 10:21 AM   #12
Erix
Originally Posted by b454rat View Post
Iíd say 3.73s maybe 4.10s. With either gear the drivetrain wonít be working as hard, so tho seems backwards but would get better mileage, while having fun at the same time lol...
Thank you !!
Old 06-21-2018, 10:50 PM   #13
Captainfab
60-66 Nut
What gear ratio do you currently have?
Old 06-22-2018, 12:48 AM   #14
Erix
Iím not sure. The label in the glove compartment door indicates GU2
Old 06-22-2018, 09:45 AM   #15
b454rat
Believe that is 3.23.....
Old 06-22-2018, 09:46 AM   #16
b454rat
Wow, it’s 2.73s.....
Old 06-22-2018, 12:20 PM   #17
Erix
Thank you b454rat ! Should I just do the locker on those gears or change. If change to what & why ?
Old 06-22-2018, 08:23 PM   #18
b454rat
Change the gears for sure!!!! At least 3.73s. Any posi that isn't the grenade lock.
Old 07-01-2018, 01:18 PM   #19
toolboxchev
If you go from 2.73 to 3.73 gears your going to kill any mileage you got from that thing. It would dramatically change they way they whole drivetrain responds to the engine. I would bet that thing is a dog right now with those gears.
Old 07-01-2018, 03:21 PM   #20
weq92f
That is a very nice looking square body right there! If you really do have 2.73 out back and a standard 700r, 1st gear off the line is probably OK, but 2nd gear must be a let down ( I'm thinking WOT here ).
If you don't want to change your current mileage/driving characteristics, don't change the gear ratio.
If you want to change the way your truck gets down the road and/or increase the fun factor stop light to stop light, change the gear ratio.
I would first make sure you know what you have currently. Determine that for certain then decide what you want to do with respect to the ratio.
-klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 07-01-2018, 03:53 PM   #21
Erix
The glove compartment sticker is:
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
