Old 07-01-2018, 12:58 AM   #26
BigRandy
BigRandy's Avatar
Re: High Torque Mini Starters
FYI: If you get in a jam with a hot starter before you get it fixed dribble a jug of water between the head and firewall.
Had an 86 with that problem and went through 3-4 starters and solenoids, Ended up selling it before figuring out why or how it kept getting heat soaked, but I kept a gallon of water with me during summer months and used the dribble trick several times and it always worked. Yes that was a cheesy trick but it got me back on the road.
BigRandy is offline   Reply With Quote
Old 07-01-2018, 01:34 AM   #27
BigRandy
BigRandy's Avatar
Dup post.... deleted
Old 07-01-2018, 09:29 AM   #28
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Originally Posted by dave`12 View Post
I had this problem. Here is a quote from Vettevet who helped me concerning the ford solenoid fix (and he is the best here).
"If the starter turns over it indicates that the solenoid is not heat soaked or it probably wouldn't even click.If you are getting a slow roll all the time when the engine is warm then the Ford solenoid is most likely not going to help."
A high torque mini starter fixed it for me.
Here is the link to my thread. Lots of good info here.
http://www.67-72chevytrucks.com/vboa...d.php?t=729029
I'm still on the fence, like I said - rebuild OE High Torque starter, re-install, run it, evaluate. If issue continues, try the solenoid kit. Evaluate, install mini starter. After that, evaluate some more...
Good info in the link you provided, not sure how I missed that one.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 07-02-2018, 12:55 PM   #29
DieselSJ
Originally Posted by franken View Post
You didn't understand what I meant, and don't know what the real issue is or how to correctly solve it.
I know what you meant.
I know what the real issue is.
I correctly solved it.
87 R30 CC Dually, TBI 454, TH400, zero rust barn find
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 07-02-2018, 04:53 PM   #30
cadillac_al
I thought we were all using these modern starters ???
http://67-72chevytrucks.com/vboard/s...+yukon+starter
FWIW I never got heat soak with the old starters either with headers.
*edit Oops, forget it, you have a SM465. Maybe it will help somebody else.
76 Chevy K20
76 GMC K15
77 Chevy C10
cadillac_al is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
