Old 07-03-2018, 07:32 AM   #1
reversrun
3 peed to 350 trans swap
Hi I just converted my 1969 c10 to auto 350 with a 250 4.1 6 cyl. and cannot get a starter to fit . The nose of the starter is to large to bolt on . I bought a starter from NAPA for this application and this starter fits cars and trucks up to 1975, part #RAY 2464791 Anyone else have this issue ? Thanks Keith
reversrun is offline   Reply With Quote
Old 07-03-2018, 01:38 PM   #2
cadillac_al
Re: 3 peed to 350 trans swap
edit - misunderstanding, I see you have a 250 with a th350 trans. You must have got a starter for a 250 powerglide. You may have to look for a starter from a 72 C10 with 250 auto. I think they were using th350's by then.
76 Chevy K20
76 GMC K15
77 Chevy C10
cadillac_al is offline   Reply With Quote
Old 07-03-2018, 02:51 PM   #3
reversrun
All starter from 1969 up are the same part number. From. NAPA. AUTOZONE CARQUEST. ETC. stumped
Old 07-03-2018, 02:52 PM   #4
reversrun
Old 07-03-2018, 02:53 PM   #5
reversrun
Even looked up cars from the same era. All the same part Thanks.
Old 07-03-2018, 05:18 PM   #6
68gmsee
Active Member
68gmsee's Avatar
I've got four starters ranging in year from 69 to 77. A couple of them used on a TH350. Can you post a picture of the starter you have? Might help id it.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 07-03-2018, 11:33 PM   #7
Captainfab
60-66 Nut
Did you use a 153 tooth flexplate or a 168 tooth? You have to get a starter to fit the size of the flexplate you used.
Old 07-04-2018, 01:06 PM   #8
reversrun
I have a 168 tooth flexplate . That's what it called for . But I believe you are correct 1.275 inch difference . 168 tooth is 14 1/8 and the 153 tooth is 12.85 . I looked it up for a 1972 c10 and that what it used . Thank you
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
