Old 05-26-2018, 06:03 PM   #1
Hollow65
Hollow65's Avatar
Ifabspeed trans crossmember
Anyone here running an ifs trans crossmember? With the new headers tucked up in the frame rails I will need a new trans crossmember to run some straight pipes. It says it built for 3” exhaust to clear and looks sweet. I’d like some feedback befor I spend the cash.https://www.googleadservices.com/pag...Qwg8IJQ&adurl=
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 05-26-2018, 06:18 PM   #2
Clyde65
Clyde65's Avatar
Re: Ifabspeed trans crossmember
I have one on my dad’s c20 crew cab. I used 2.5” tubes but they are tucked nicely and mine canmepowder coated as well.
I’ll probably get one for my short bed as well
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-26-2018, 06:24 PM   #3
Hollow65
Hollow65's Avatar
Right on. Thanks for the reply. I’m pulling the trigger.
New headers are a wee bit shorter than the hooker supercomps. Sounds good open header, but I don’t want to make the neighbors too mad.
Old 05-26-2018, 08:06 PM   #4
Clyde65
Clyde65's Avatar
I’m all for p*****g off the neighbors!!
Clyde65
Rebuild of Clyde
support our troops!
Old 05-26-2018, 08:46 PM   #5
raidmagic
raidmagic's Avatar
What was the motivation for switching headers? Do you still have the stock e brake?
raidmagic is offline   Reply With Quote
Old 05-26-2018, 09:47 PM   #6
Hollow65
Hollow65's Avatar
Supercomps cracked at the collector/flanges were wacky, had to run doubled up gaskets on both heads. Hedmans were $200. Couldn’t resist. As for e-brake, if it came to needing it I would aim for a tree.
Old 05-27-2018, 07:27 AM   #7
The Rocknrod
Moderator
The Rocknrod's Avatar
Attachment 1787679
What is the part number on those headers? Where do they exit below the frame? or above it?
Old 05-27-2018, 09:41 AM   #8
Hollow65
Hollow65's Avatar
Hedman 69230
I’ll try and get some photos today. I store the truck at my fathers.
Old 05-27-2018, 09:56 AM   #9
raidmagic
raidmagic's Avatar
lmao. I am keeping the manual so I'm going to need one. I can't park against a tree everywhere.
Old 05-27-2018, 10:37 AM   #10
Hollow65
Hollow65's Avatar
Yeah, no e-brake. The headers exit right at the starter. I can fan some exhaust but it’ll have to bend right away to clear the current crossmember and go below the frame. I’ll get ifs crossmember and see how it works. I have all my exhaust pieces sitting in the garage. Flow master 40’s and 8’ of 3” tubing plus the socket ends to mate to the new style headers. I think the egts are going to play hell on my starter so I’ll be buying a thermo shield for that. Lots of little stuff I will need but I think it’s worth it. I’m going to take it out today open headed and blow some cobwebs off it. Haven’t started it since mother’s day. Wish I could post a video, it sounds pretty cool open header. Stupid loud in the cab though.
Old 05-27-2018, 10:38 AM   #11
Hollow65
Hollow65's Avatar
Raid, aren’t you doing an ls-swap?
Old 05-27-2018, 01:36 PM   #12
raidmagic
raidmagic's Avatar
Yes, LS1 from a 98 Trans Am with a manual.
Old 06-02-2018, 11:49 AM   #13
Hollow65
Hollow65's Avatar
Got the crossmember 5/31/18
Looks awesome, gonna put it in today with the exhaust.
Old 06-05-2018, 02:44 PM   #14
raidmagic
raidmagic's Avatar
Soooooooooooo? How did it go?
