12-06-2018, 12:10 AM | #1 |
Courtesy light -+ trigger?
85. Wiring diagram is confusing. Question is regarding the dome lite. I assume one side is constant hot OR constant ground. The other side that goes to the light switch...is it ground or hot?
I know this sounds elementary but I'm working on a Custom Deluxe (i.e. no dome light from factory). Just don't want to create a short when I tie it into the pin switches I installed for the alarm. |
12-06-2018, 01:46 AM | #2 |
Post Whore
Re: Courtesy light -+ trigger?
Hot to the light...the ground from switches is what triggers the light...
12-06-2018, 12:52 PM | #3 |
Msgt USAF Ret
Yes that is right and on most GMs the constant hot is orange and the switched ground is white. look at the light switch for a white wire which is the ground/switch for the dome light.
The alarm should be specific as to which wire you'll need but I would think it will tie into the white wire since that feeds all the other switches if not deactivated.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
