07-22-2019, 02:43 PM | #26 |
Re: 350 Zero Compression #3 and #5
Block seal. Got a junk radiator you can sacrifice? That will buy you time.
I've had 4.3's with head cracks. Got hundreds of thousands of kilometers out of them using a sealer. BTW Bars leak will not clog radiators. I know because a fan let go and went through one. I was surprised to see it OK inside. |
07-22-2019, 07:12 PM | #27 | |
You know, good machinists can locate good cores and make them nice. I think Summit has bare blocks and short blocks. Lots of good options to get you back on the road. The money part is a pain, though. EDIT: It looks like the Summit remanufactured bare blocks are already $700-1000. Yeouch! EDIT AGAIN: It looks like the $1000 bare block is brand new from GM.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 Last edited by mattfranklin; 07-22-2019 at 07:23 PM. |
07-22-2019, 07:39 PM | #28 | |
Considering an LS swap, just don't know if I really want to dive into that or not. Either that or a block and swap everything over. Still debating on how much time and money I want to dump into this thing. |
07-22-2019, 08:02 PM | #29 |
i like my almost bolt in 100% L31 vortec engine i got new from gm for 1850.00 . this got me around 280 hp and roller cam and brand new engine .
just needed intake swap and a plug for the crank sensor on the front cover and a bypass hose like bbc uses to the intake from the water pump and she was in and running . not sure what year your truck is or current fuel system . ?
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
07-22-2019, 08:11 PM | #30 |
Post Whore
id switch to LS before id drop a bundle on a SB bare block for 700-1000
07-23-2019, 01:02 PM | #31 |
The LS motors are really tempting with our old SBC motors getting harder and harder to find parts for.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 |
07-23-2019, 01:20 PM | #32 |
SBC parts hard to find? That's a new one on me. Put a new head gasket on it and run it. So you're out money wise 1 head gasket/intake and some labor. what tk is it in?
1961 chevy K10 my build is------------61K10 build |
07-23-2019, 02:10 PM | #33 | |
TK is NP205... |
07-23-2019, 04:36 PM | #34 |
Post Whore
No issues finding a sbc or parts for one around here...I'd just have a hard time dropping that much $$ to buy a replacement block
07-23-2019, 05:19 PM | #35 |
Could always try this stuff: https://www.jbweld.com/products/highheat-epoxy-putty
Use one of the thin metal head gaskets and the temps should stay under the limit. Probably won't last forever but might buy you some time to find a good solution while still letting you drive the truck. |
07-24-2019, 07:37 PM | #36 | |
07-24-2019, 08:15 PM | #37 |
I do believe that crack goes down into the water jacket. Working on mine with the heads off I can feed a wire through the top holes from side to side between the cylinders.
https://www.youtube.com/watch?v=b2xT-pKdOrc I'd use something like this. There are a bunch of products out there but I don't know whose is the best. |
09-24-2019, 08:02 PM | #38 |
After a lot of personal debate with myself on what to do, I pulled the trigger on a LQ4/4L80E today. I'll try to snap some photo's and document the swap a bit. I think in the long run, I'll be much happier going this route for what I use my truck for than sticking with the stock 350/350...
09-26-2019, 11:41 AM | #39 | |
