05-11-2011, 02:17 PM | #1 |
Resident of Here
TBI Upgrades?
What are some way to upgrade an 88 TBI 350, to help mileage. I know the usual, intake and exhaust. I don't know anything about TBI... Thanks, Bradley
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
05-11-2011, 10:53 PM | #2 |
The Engine Whisperer
Re: TBI Upgrades?
Throttle body spacer is nice. As is an injector pod spacer.
-Automatics win races, 6-speeds impress high school kids -Save a tree, support your local dragstrip. -"Failure - The Secret To Success, the idea is that you can fail 100 times as long as you can succeed once" -Takeo Fukui columbuscarsandcoffee.net and on Facebook |
05-11-2011, 11:18 PM | #3 |
Chris
Re: TBI Upgrades?
agreed and to help mileage normal tune up items, oxygen sensor, plugs, wires, cap, rotor, coil, air cleaner, smoothing out the air path to it. exhaust as you mentioned. but most are for power and not mileage.
Chris GIT R DONE!!!!!! Check out all our rides, http://www.cardomain.com/id/benwa454 |
05-11-2011, 11:40 PM | #4 |
60-66 Nut
Re: TBI Upgrades?
A custom or aftermarket chip should help some along with the above mentioned.
05-12-2011, 01:39 AM | #5 |
Resident of Here
Re: TBI Upgrades?
Thanks guys, will get to it after I buy it.
05-13-2011, 06:33 PM | #6 |
Re: TBI Upgrades?
I agree with the basic tune-up items including the o-sensor.
2nd I would first work on the exhaust...you can keep the manifolds if you want but open up the rest of the exhaust or move to a true dual set-up. 3rd, help it breathe in....get rid of the stock air-cleaner assembly and put on an open element. 4th, get a better coil and plug wires. Give it some real spark!!!! After this you will have to open er up. Manifold and cam. Then a chip. Check out www.tbichips.com |
05-14-2011, 12:00 AM | #7 |
Resident of Here
Re: TBI Upgrades?
What cam would give me better mpg? I've read a Tow/RV cam would, but I dont know.
05-14-2011, 07:36 PM | #8 |
Re: TBI Upgrades?
Everything mentioned is 100% correct. My truck already came with the dual exhaust, but when I added the throttle body spacer, that really woke this engine up.
Not sure on the cam, but remember, getting the proper tune after messing with cam or heads is a MUST with TBI.
87 Chevy 2wd SWB: 305/700r4 Dual Exhaust, K&N Filter, Injector Pod Spacer, TBI Spacer, Belltech Front Sway Bar, Corvette Servo, Western Chassis 4/6 and c-notch |
05-15-2011, 12:43 AM | #9 |
60-66 Nut
Re: TBI Upgrades?
Before purchasing a new cam, I would suggest talking to some people that tune TBI's and or burn the chips. Some cams are a big PITA to get to run right with EFI. This is why there are EFI specific cams. Although some of the other cams are tuneable in a EFI application.
05-15-2011, 10:55 PM | #10 |
yes, i do
Re: TBI Upgrades?
hey tito, i got a spacer that you can have. pm me
ERROR 404....... SNAPPY COMEBACK NOT FOUND _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
05-16-2011, 01:41 PM | #11 |
Chris
Re: TBI Upgrades?
I want a spacer.
05-16-2011, 11:21 PM | #12 |
Re: TBI Upgrades?
Get a used set of cast iron vortec heads. Stock TBI heads just do not flow good in comparison. Some even claim a 40 hp gain just with the head swap. I don't know how true that is, but you can some times find a set of those heads (96-98 ck truck/suv) for under a 100.00.
And definately talk to Brian at www.tbichips.com He knows his TBI stuff. I dropped a stock Vortec long block from a 96 truck into his 93 along with a GMPP intake, stock tbi with a chip,fp regulator spring, and fuel pump from TBIchips.com Much more power, great SOTP (seat of pants) feel and better gas mileage running 87 octane.
68 C10 Shortbed Fleetside 06 Chevy Ext Cab Fleetside 03 Grand Prix GTP My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=269999 |
05-17-2011, 10:12 AM | #13 |
Re: TBI Upgrades?
Yes the vortec heads are great and now you can find them fairly cheap but costwise it is that GMPP manifold (the ONLY manifold that bolts to Vortec heads and is designed for the TBI throttle body) that holds me back. It is around $400!!!!!
05-17-2011, 03:17 PM | #14 |
Re: TBI Upgrades?
i have a spacer and i didnt notice any difference but might be me, vortec heads as mentioned and the intake which gm sells and i thought edelbrock as well but i might be wrong on that
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854 1988 IROC-Z Camaro - 305/T5 T-Top 1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850 1991 V2500 Suburban Silverado - Sold 1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423 2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold 2003 1500 Silverado 2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold 2005 Silverado 2500HD 6.6/ZF6 CC LWB |
05-17-2011, 04:20 PM | #15 | |
Re: TBI Upgrades?
This combination provides a low cost solution and TB spacer comes for free. //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
05-17-2011, 07:25 PM | #16 |
Chris
Re: TBI Upgrades?
I too had heard that, run a dual or single plane intake and a tbi adapter plate and be done. Alot cheaper.
I heard the high rise single plane intakes are best for this since tbi isn't a carb the rpm range doesn't matter? not sure on that one at all.
