03-20-2018, 04:12 PM | #1 |
Drive shaft width?
I have heard alot of people say that they have used a drive shaft out of a wrecking yard.A friend of mine gave me a drive shaft out of his mid 70's nova and its a perfect fit but it's thinner than my old drive shaft.Would this be acceptable also do you think they make bastard ujoints for this?
03-20-2018, 04:43 PM | #2 |
Post Whore
Re: Drive shaft width?
driveshaft diameters and thickness are usually determined by length and hp/tq...not sure what ujoint your needing but I know there are some with differences in size...
03-20-2018, 05:49 PM | #3 |
U-joints are fairly standard (Spicer 1310, 1350, and so on), with a few exceptions (some weird internal clip Ford and Chrysler stuff). Just google u-joint dimensions and compare to measurements of your own.
Also, I have seen *special* adapter ones where one way it's a 1310 and the other way it's a 1350. Like this one: https://www.amazon.com/EXCel-95-0460.../dp/B01I3X84EE
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1 http://67-72chevytrucks.com/vboard/s...d.php?t=567340 Last edited by mattfranklin; 03-20-2018 at 05:52 PM. Reason: forgot a link |
03-20-2018, 07:34 PM | #4 | |
Posted via Mobile Device |
03-21-2018, 09:38 PM | #5 |
IMG_20180321_185347.jpg Not even a 1/16 difference.
03-22-2018, 11:43 PM | #6 |
[QUOTE=richards72chevy;8218377]IMG_20180321_185347.jpg Not even a 1/16 difference.[/QUOTE
That’s all it takes to lose the driveshaft at high speeds. Posted via Mobile Device |
03-22-2018, 11:52 PM | #7 |
03-23-2018, 07:45 AM | #8 |
[quote=YoungPup1977;8219297]I'm going to Napa today if they don't have the correct conversion ujoint I'm thinking I will just have a new drive shaft made.
03-23-2018, 11:04 PM | #9 |
60-66 Nut
Why not just have the yoke changed? That will be a whole lot cheaper than making a complete new driveshaft.
[quote=richards72chevy;8219386]
03-24-2018, 08:36 AM | #10 |
That was the yoke that came with the transmission plus I needed new ujoints.
03-24-2018, 05:23 PM | #11 | |
03-25-2018, 09:18 AM | #12 | |
03-27-2018, 07:27 AM | #13 |
When you say you have an inch of play....is this when the vehicle is setting on all 4 wheels or is the rear of the vehicle off the ground ? As you know when you lower the vehicle to the ground your driveshaft will move towards the transmission, so make sure how you are measuring the driveshaft for proper length.
03-27-2018, 10:08 AM | #14 |
Yes all four wheels are on the ground.
03-27-2018, 12:03 PM | #15 |
What was the reason why you were not using the original driveshaft ? Tossing in a driveshaft you know nothing about could bring you issues..... how do you know the nova driveshaft is balanced/not bent/etc ?
03-27-2018, 01:42 PM | #16 |
The original was to long my truck originally had a straight 6 and a manual transmission.I know the risk hopefully its not messed up.I would have preferred to have new one made but my issue is I'm stuck at work monday through Friday 11 hours a day.I don't think any of the places that would make a drive shaft are open on weekends.I'm a welder I know my boss would have let me cut it down and shorten it at work but I've been told that it would have to be rebalanced.
03-29-2018, 01:20 AM | #17 | |
If you can find a decent caliper and take some accurate measurements, you can find the right joint. I used to go to O'reillys and look through their Master Pro book which listed the conversion joints by dimension. Find your part number, cross reference to Spicer, order and done. The last time I went through the drivelines (3 driveshafts), I went as far as changing the input, output yokes on the trans and T Case, building new driveshafts just so I didn't have 6 different joints. I think I only have 2 different types now which is still a relief. Captain hit it on the head though. Have the old yoke cut off and replaced with the right size yoke. And while the guy is at it, have him get the right joint for you and install it. Its also not a bad idea to have the DS checked for balance. It doesn't take but a little ding to make a good set of joints go to crap or worse. I was in a truck that lost a cobbled up jack shaft to the t case on the freeway. No thanks.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
03-30-2018, 10:20 PM | #18 |
Denny's driveshaft website
04-03-2018, 08:23 AM | #19 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
https://www.ringpinion.com/b2c/Parts...D=24&CatID=113 Kinda pricey...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
