04-24-2013, 09:26 AM | #1 |
Q on adapter
I'm working on removing the incorrect broken np203 from my rig and putting a correct/working np205 in that came from a 73/74 model. my trans is a th350
I picked up a 205 and luckily it has an adapter. Sadly, after I found a shifter and bolt, I found out the holes were stripped. I first thought about doing a heli-coil fix. The kit is fairly expensive, plus I dont have a drill to handle the bit I would need. Looked at a new one from summit. All I have to say is Slightly hunted for some used adapters. I am finding a wide variation on these and not sure whats what, so I'm wanting some help here on making sure I get the right one. I'm wanting to know what year(s) these options where around. I know there were two bolt sizes used. 1/2 or 9/16. There is a figure 8 pattern, and round pattern. Any other things I need to be aware of?
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half RIP 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) Last edited by Dale99; 04-24-2013 at 09:33 AM. |
04-24-2013, 10:35 AM | #2 |
Re: Q on adapter
ok, so it appears there is an adapter with bearing, or adapter with seal.
04-24-2013, 11:40 AM | #3 |
One of the First
Re: Q on adapter
Try looking on ebay and then put WTB on the parts board. The TB 350/NP 205 adapter usually runs around $75 / $150 used. Also start calling Junk yards - these adapter were used from early 70's to late 70's in K5, K10 and K20's.
Plus research on line...
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
04-24-2013, 01:27 PM | #4 |
Re: Q on adapter
Ive found some, I just want to figure out the differences so when I buy I know its the right one. Ive bought many parts for this truck to get them and find out they are wrong. Then have problems selling at a loss... if they sell.
04-24-2013, 07:18 PM | #5 |
Re: Q on adapter
just design changes. the last one was 1980 for the 27 spline.
i have two seal style adapters. pretty sure they are later style, not sure when because the tags on the 205 were gone. wish i could help more. wither one will work fine, just get the corresponding coupler style. |
04-24-2013, 08:33 PM | #6 |
Re: Q on adapter
Will a "bearing" style adapter work on a "seal" style coupler?
04-24-2013, 09:00 PM | #7 |
Re: Q on adapter
its been a while since ive seen them beside each other, pretty sure they dont but cant remember why.
04-24-2013, 09:32 PM | #8 |
Re: Q on adapter
Thanks. Just bought one off evil bay and comes with coupler, mounts, bolts, and whole bunch of stuff. Hopefully I can make it all work.
