02-24-2019, 11:23 AM | #1 |
250 intake and exhaust manifolds
Can they be milled? I’m getting leaks on both. After replacing the gasket, they continue to do the same.
02-24-2019, 12:23 PM | #2 |
Re: 250 intake and exhaust manifolds
Did you separate them or at least loosen them to install them?
02-24-2019, 01:32 PM | #3 |
I had to take out of them off to get to the gasket. It’s not an integral head.
Posted via Mobile Device Last edited by prodjay10; 02-24-2019 at 01:42 PM. |
02-24-2019, 04:22 PM | #4 |
Separate them then.
Once they’re both in place bolt them back togethor. |
02-24-2019, 08:48 PM | #5 |
Understood. Thank you.
02-25-2019, 03:31 PM | #6 |
Active Member
Some years ago mine was leaking and couldn't keep a gasket on them (exhaust manifold was a new one). I asked the machine shop and they said bring the intake and exhaust bolted together. Not sure how they machined it but it hasn't leaked since.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
02-28-2019, 08:00 AM | #7 |
Six in a row makes it go...
Both of mine got milled, and needed it, during the rebuild.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
