Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Misc. For Sale
Old 03-24-2019, 08:23 PM   #1
Madkidd007
Madkidd007's Avatar
He341 turbos
Sold!!!
I’ve got one he341 holset turbo left. Factory for a 5.9 24v Cummins. Was on my truck before I went one size larger. Does have some shaft play but not enough for the blades to touch the compressor or exhaust housings. The pictures I’m posting are of the used one I Already sold but will update with actual pictures which will be post 4
Specs pulled from the net:
Compressor Wheel: 56mm/76
Turbine: 58mm/65mm
Turbine housing 9cm^2
Undivided housing
Take $150 plus shipping.
70 C10 highschool truck now C20 cummins powered
72 Crew Denali, Bigger, Stronger, Faster, well you get the point.....
the ole 65 continental
Syclone killer AWD T56 LS
Paypal please pay as Goods&Services Madkidd00000007@yahoo.com
Madkidd007 is offline   Reply With Quote
Old 03-24-2019, 08:25 PM   #2
Madkidd007
Madkidd007's Avatar
Re: He341 turbos
More detail
Old 03-28-2019, 05:03 PM   #3
Madkidd007
Madkidd007's Avatar
Re: He341 turbos
1st one of unknown condition sold on eBay, the one off my actual truck still available but will be going on eBay tonight
Old 03-28-2019, 06:35 PM   #4
Madkidd007
Madkidd007's Avatar
Re: He341 turbos
Housing was modified by drilling mounting holes to use on a flipped manifold, so it now uses four bolts instead of two bolts and two studs. Personally run on my truck for 3-4 months, with the wastegate hose zip tied it would boost to 32 lbs on a VE 12 valve with 5x0.12 injectors. Center section was rotated to reclock but can easily be rotated back to stock location for use on a factory truck.
Old 04-08-2019, 09:38 PM   #5
Madkidd007
Madkidd007's Avatar
Re: He341 turbos
Sold on the ebay
