Old 01-16-2009, 12:38 AM   #26
SCOTI
SCOTI's Avatar
Re: you want to change your 5X5 bolt pattern on 73-87 disc to 5X4.75
Ahhh.... The numbers may not mean anything then (because of the different calipers). The set-up I have is OE S10 (11" rotors IIRC) w/OE rear emergency brake.
I have everything minus one rotor that my buddy mis-placed some where along the line. I'll try & grab a rotor & put it inside a wheel & measure from the wheel 'pad' to the inside rotor surface (right?).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 01-16-2009, 08:49 AM   #27
babyblueoval
babyblueoval's Avatar
I just put the rotor hat down on the counter at the parts store and put a straight edge across the top. That is how I got the measurements and they are the same as stated in dimension info.
Jim
'71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E
'57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works
'87 BMW 325i - daily driver
babyblueoval is offline   Reply With Quote
Old 01-16-2009, 09:53 AM   #28
SCOTI
SCOTI's Avatar
Will do.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-03-2009, 01:37 AM   #29
Grip
Grip's Avatar
If you want to convert to the car bolt pattern with factory parts, check with a wrecking yard that uses the Hollander Interchange books. I found that a 71-72 (if I remember the year correctly) G-10 van had the same upper and lower control arms as a C-10 truck, but used the car 4.75" bs rotors. Just score the spindles and for a bolt on conversion. I used this setup years ago to convert a 73 C-10 that I pro-streeted. I had 15X3.5" weld drag lites and they didn't make them in 5X5 bs.
Grip is offline   Reply With Quote
Old 03-03-2009, 09:41 AM   #30
N2TRUX
Happy to be here
N2TRUX's Avatar
Welcome to the forum Grip we appreciate your input. I am a bit confused as I have always known all GM 1/2 ton trucks, vans, Burbs etc to have a 5x5 pattern.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-03-2009, 12:07 PM   #31
duceducenine
duceducenine's Avatar
not to confuse things too much....
i want to do the opposite camaro clip with 5 on 5 bolt pattern...[56 sub]
so all i need is 81+ 1" rotors using the camaro spindle? caliper?
or do i still need to use the truck caliper brakes?
can i put a truck spindle on the camaro a-arms w/ truck bj's?
duceducenine is offline   Reply With Quote
Old 03-03-2009, 12:26 PM   #32
Grip
Grip's Avatar
Were there's a will there's a way...Try A&A mfg or UB machine. They both make weld in ball joint bushings that take common Moog ball joints. Just figure out the taper of your ball joint holes in the spindle and adapt your a-arms using the correct weld in ring.
Old 03-03-2009, 12:38 PM   #33
Grip
Grip's Avatar
Thumbs up Re: you want to change your 5X5 bolt pattern on 73-87 disc to 5X4.75
N2TRUX, Thanks for the welcome. I have been trolling for quite a while but finally decided to sign up. I grew up in a wrecking yard and it was 1987 when I last did the spindle swap. I called my dad who still runs the yard. He is going to look up the interchange # for me. I'll post it as soon as I hear back from him.
Old 03-03-2009, 09:52 PM   #34
Grip
Grip's Avatar
More info...I looked up the rotor for a 71 G-10 and found this on Napa's website:
It list a BUNCH of cars that are 4.75 bs as interchange
Rotor & Hub Assy - Front - Premium
2 Images
<< Prev Next >>
Front
Part: NB 4885542
Product Line: NAPA Brakes Rotors & Drums
List Price
Your Cost
Unit
93.16
62.80
Each
Qty
Features & Benefits
NAPA Premium Rotors Are Designed To Improve Stopping Distances, Minimize Brake Fade & Extend Pad & Rotor Life.; The Non-Directional Finish On NAPA Premium Rotors Reduces Noise & Braking Roughness.; Vane Configuration Reduces Temperatures & Improves Performance.
NAPA Brakes - Complete Line-Up
Attributes
# of Bolts : 5
Bolt Circle Diameter : 4.75"
Brake Rotor Diameter : 11.005"
Brake Rotor Discard Thickness : .965"
Brake Rotor Thickness New : 1.035"
Brake Rotor Type : Disc Brake Rotor & Hub
Height : 4.639"
Includes ABS Inner Sensor Ring : No
Includes Inner Bearing Cup : Yes
Includes Outer Bearing Cup : Yes
Maximum Lateral Runout : .004"
Mounting Type : Type J - 1 Piece Or Integral Hub & Rotor Assembly. Rotor & Hub Are Cast As A Single Unit. Wheel Studs Are Pressed Into The Rotor. See Diagram For More Information.
Vented / Solid : Vented
Warranty
12 Months or 12,000 Miles Whichever Occurs First
Warranty PDF
Material Safety Data Sheet (MSDS)
There is no MSDS for this item
Application Information: 1971 Chevrolet Truck G10/1500 1/2 Ton - Van
Per Car Qty: 2
Buyers Guide
Make Model Engine Year(s)
Buick Apollo 1975 - 1975
Buick Century 1973 - 1977
Buick Estate Wagon 1977 - 1978
Buick Lesabre 4.9 L 301 CID V8 1977 - 1978
Buick Lesabre 5.0 L 305 CID V8 1978 - 1978
Buick Lesabre 5.7 L 350 CID V8 1977 - 1978
Buick Lesabre 6.6 L 403 CID V8 1977 - 1978
Buick Regal 1973 - 1977
Buick Skylark 1975 - 1978
Cadillac Seville 1976 - 1976
Chevrolet Camaro 1970 - 1978
Chevrolet Caprice 1977 - 1978
Chevrolet Chevelle 1973 - 1973
Chevrolet Impala 1977 - 1978
Chevrolet Malibu 1973 - 1977
Chevrolet Monte Carlo 1973 - 1977
Chevrolet Nova 1975 - 1978
Chevrolet Truck El Camino 1973 - 1977
Chevrolet Truck G10/1500 1/2 Ton - Van 1971 - 1974
GMC Truck G1500 1/2 Ton - Van 1971 - 1974
GMC Truck Sprint 1973 - 1977
Oldsmobile Custom Cruiser 1977 - 1978
Oldsmobile Cutlass 1973 - 1977
Oldsmobile Delta 88 1977 - 1978
Oldsmobile Omega 1974 - 1978
Oldsmobile Vista Cruiser 1973 - 1975
Pontiac Bonneville 1977 - 1978
Pontiac Catalina 1977 - 1978
Pontiac Firebird 1970 - 1978
Pontiac Grand Am 1973 - 1975
Pontiac Grand LeMans 1975 - 1977
Pontiac Grand Prix 1973 - 1977
Pontiac GTO 1973 - 1973
Pontiac LeMans 1973 - 1977
Pontiac Parisienne 1977 - 1978
Pontiac Phoenix 1977 - 1978
Pontiac Ventura 1975 - 1977
Old 03-04-2009, 02:12 AM   #35
67 cst swb
67 cst swb's Avatar
Well, you are correct on this... In addition to 71-72 there is also 73-74 G-10 vans. These (71-74 G-10) use the 70-78 camaro rotor & caliper. So, there are numerous outlets for big brake kits. Bear, SSBC, etc...
There is a difference between 71-72 & 73-74 G-10 Spindles, the outer tie rod mount is different. It's thicker where the taper of the outer tie rod goes thru the spindle.
As far as the outer tie rod ends used:
71-72 G-10 is same as 71-72 C-10
73-74 G-10 is same as 73-74 C-10
If I remember correctly, the 73-74 tie rod hole is thicker top to bottom.
In 75 G-10 went to 5 on 5 bolt pattern.
I have a set of each 1) 71-72 G-10 van spindles complete & 1) 73-74 G-10 van spindles complete.
My plan was to build a race truck style build and use cross drilled rotors that are commonly available for 70-78 camaro rotors as well as aftermarket race caliper (wilwood, strange, etc...) I actually had them mounted on a rolling frame for awhile with 15x7 ralley's for about a year before I changed my vision for the project.
P.S. yeah, I've worked in auto parts for 22 yrs, 5 yrs of that at NAPA, so, had lots of time to research stuff like this...
If you wanna talk using stock parts to come up with 6 on 5-1/5" disc brakes PM me, I've researched that as well, If I remember SCOTI helped me on that deal... that was awhile back, If SCOTI doesn't remember helping out, I'll take FULL credit for the research.... Just kidding SCOTI.
Bryan
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red
67 cst swb is offline   Reply With Quote
Old 03-04-2009, 08:11 AM   #36
babyblueoval
Part: NB 4885542
Height : 4.639"
67 swb cst,
What is the "Height" measurement in the specs measuring?
Is that how tall it is from rotor hat to the rear disc surface?
If it is, I'm trying to find something that's much closer to 2.335.
Thanks,
Jim
Jim
Old 03-04-2009, 10:19 AM   #37
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks for the info Grip and 67 cst swb. I always hear guys talking about running van rallies on the front because they are narrower than truck rallies. I had never heard that there were specific years that were not 5x5.
And now I know "the rest of the story"...
Articles-
"Refining Sierra"
Old 03-04-2009, 02:00 PM   #38
gringoloco
A guy with a truck
gringoloco's Avatar
Yes on the rotors. Use '81-up 1" truck rotors or B-body(Caprice)- same part number. They will still use the car calipers.
On the spindles- not that I'm aware of, but I seriously doubt it...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 03-06-2009, 03:02 AM   #39
67 cst swb
67 cst swb's Avatar
67 swb cst,
Thanks,
Jim
Sorry if I caused confusion...
The area that is thicker is where the outer tie rod mounts to the spindle (the tapered hole on the spindle). It is the same on the 73-74 G-10's as the 73-79 C-10. (I will edit this info above)
The 71-72 G-10 tie rod end mount thickness is the same as 71-72 C-10's.
BUT, 71-72 years are different than the 73-later (73-later being the thicker of the two)...
Check back to this thread later, as soon as I can I will get you the measurments.
My Trucks:
Old 03-06-2009, 03:14 AM   #40
67 cst swb
67 cst swb's Avatar
Ok, this has also sparked my interest...
What year camaro clip/subframe/rotor are you currently using? I may have a simple fix for you, but I need more info.
If it's easier for you... Call me at work 605-348-3850 M-F (9-6 MT)
I think I know how you can get a bolt on 5 on 5 bolt pattern rotor to go onto a stock camaro spindle (depending on year spindle used).
My Trucks:
Old 03-13-2009, 12:40 PM   #41
b00sted
b00sted's Avatar
If you have the 85 style front end and use the 91 camaro rotors why do you have to use the camaro calipers?
They seem to be the same size???
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 03-13-2009, 07:06 PM   #42
gringoloco
A guy with a truck
gringoloco's Avatar
If you have the '85 LD brakes, you can keep the calipers. Only thing you will need to swap is rotors...
-Chris
Old 03-13-2009, 08:17 PM   #43
b00sted
b00sted's Avatar
here is a dumb one for ya.. How can you tell if they are light duty or heavy duty? This clip is under my 53...
Old 03-13-2009, 09:54 PM   #44
N2TRUX
Happy to be here
N2TRUX's Avatar
Measure the thickness of the rotor. If they are new, they should be 1" or 1.25" for HD.
Articles-
"Refining Sierra"
Old 03-14-2009, 01:27 AM   #45
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Bryan
Man let me in on that, I would love to do a six lug conversion!
heavychevy79 is offline   Reply With Quote
Old 03-15-2009, 06:20 PM   #46
b00sted
b00sted's Avatar
I just want to make sure I am correct on this..
My rotors measure 1.25.. I need to get the 91 1" camaro brake rotor for the perfromanc epckg and calipers to make the swap? Or could I just buy the light duty calipers for the 85 truck and use them with the camaro rotors? This way I won't have to worry with a metric brake line?
Thanks for the help with this...
Old 03-15-2009, 10:09 PM   #47
87 dually burb
my short bus
87 dually burb's Avatar
x2 on the the 6 lug swap
for a 90 burb with 1.25 rotors
lookin to run 07-08 tahoe 20"s
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 03-15-2009, 10:27 PM   #48
gringoloco
A guy with a truck
gringoloco's Avatar
You will not be able to do the swap. You need the '81-up LD spindles...
Best bet is aftermarket rotors. There is also a conversion floating around here somewhere that uses '88-'98 stuff...
-Chris
Old 03-16-2009, 04:34 AM   #49
meansting04
meansting04's Avatar
now if someone could just make a drop spindle for us drum guys it would be great to run nice wheels a good drop and drums
67 gmc 1/2 ton, 5.0 v6, 4 speed SOLD!!
70 Chevy C-10, 355, th400, 3.73's 2/4 drop
meansting04 is offline   Reply With Quote
Old 03-16-2009, 08:56 AM   #50
87 dually burb
my short bus
http://67-72chevytrucks.com/vboard/s...d.php?t=322587
found some info here that may help
